JBL Marine MR-4.2/4CHx45Watts/Compact disc player/ detachable system - the radio plays fine, however when a cd is put into the player is just reads loading over and over until it reads error and stops?
  • Anonymous Apr 26, 2009
    same thing. ERR 2 is what I get after about 5 min. of loading.
SOURCE: Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Posted on Jun 06, 2007
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
  • 77 Answers
SOURCE: CD Player doesn't work; says "disc"
i would say that your lense is dirty and yes cleaning it might help
Posted on Feb 11, 2008
  • 319 Answers
SOURCE: Kenwood DP-MH5 CD Player won't
CDs can be removed but you must use great caution not to break or bend mechanism components. Its better to have unit serviced by pro/tech
Posted on May 10, 2008
SOURCE: Sony Compact Disc Player (CDX-L380/
Sony Technical Advice say to try pressing the 'Reset' button - or else contacting a repair agent.
Posted on Jul 31, 2008
My nx501 says invalid disc when I put a cd in I
Clarion NX501 Owner Manual Installation Manualit looks like this is mainly a dvd player,it does play disks with mp3's and wma files but,not compact disc files,read the manual,try a recorded cd with mp3s,
DVD Player System
Digital Versatile Disc System with CDDA capable
Usable discs:
DVD video disc, Compact disc
Frequency Response: 20 Hz to 20 kHz
Sound/Noise Ratio: 95 dbA (1W Ref)
Dynamic Range: 95 dB (1 kHz)
Distortion: 0.05%
Video system: NTSC/PAL
May 22, 2015 | Televison & Video
Tried several CDs
Try to reset the radio by unplug the power source to the radio
Sep 22, 2009 | Dual Car Audio & Video
Won't read the CD's now
have you ever cleaned the lazer lens? goto any CD store and pick up a CD cleaner CD, it is a CD that you place a drop of cleaner on the brushes on the bottom of place it in the CD player and let it play, it will clean the lens that reads the cd, you might have to run it a few times if you have never done this before. that should fix the problem. the CD cleaners are not that expansive, can find them under $20...... hope this helps you..........
Jun 01, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
No disc appears even though a disc is in it - correct side up
Either the CD player does not support the format of the CD or the reading lens insidemight be covered with dust. Use a CD lens cleaner to rectify this problem.
Nov 28, 2008 | Audio Players & Recorders
JBL MR-4 CD doesn't eject
The unit probably doesn't think there is a CD inside. Possible doing a soft reset will fix this. Do so by powering the unit and putting a ball point or other pointed object into the reset button opening either on the face of the radio or behind the face. A hard reset can be done by disconnecting constant power from the unit for approximately 15 seconds.
If either of these methods fail, then your unit has a bad CD mechanism or more than 1 CD inside the player. In that case, the unit will have to be serviced by an electronics repair or a local stereo shop. This is a Marine radio, and if installed on a boat, this problem is not too uncommon. Moist air can cause damage to the unit as well as the bouncing on the water that boats do.
Aug 11, 2008 | JBL - MR4W Am/Fm with CD Player White
Problem with compact dic player
contact your installer of the spa they will determine what needs to be done as I dont have enough info to assit you
Mar 26, 2006 | JBL MR-4 AM / FM / CD 180 Watts Marine...
178 people viewed this question
 Grubhead
Grubhead
