Question about Estate TMH16XS 1000 Watts Microwave Oven
Turntable is not spinning - Estate TMH16XS 1000 Watts Microwave Oven
  • Estate Master
  • 6,771 Answers
This is a common problem in a lot of different brands, The turntable motor is defective and will need to be replaced to remedy the issue.
Posted on Mar 19, 2011
Why doesn't Frigidaire FGMV174KBB microwave turntable turn?
Good Morning Friend,
I understand that the turntable is not spinning on your Frigidaire microwave, model# FGMV174KBB. There is a possibility that your microwave is in a "Turntable off" mode. To turn the turntable back on, press the "turntable on/off" button.I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire Microwave Ovens
Turntable not rotating
Most likely the gear is stripped. Pull up the turntable and then run it. Watch the wheel and see if it is spinning without the turntable.
Jan 23, 2013 | Hotpoint RVM1635 Microwave Oven
Turntable will not run - free spinning
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
IUf just spins without resistance, it may be a broken turntable coupler or turntable motor.
It will require checkout. You should be able to remove the bottom panel of the microwave to remove these for inspection.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Dec 27, 2012 | Microwave Ovens
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
Did you check the coupler? Take plate out and where the plate sits grab it and see if it just spins freely if so it's the coupler. If not it probably is in the wiring.
Sep 16, 2009 | Hotpoint RVM1435 Microwave Oven
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
Danby turntable keeps spinning
2 THINGS COME TO MIND--A BAD ELECTRONIC CONTROL PANEL (BEHIND THE KEYBOARD) USUALLY FROM A POWER SURGE,,,,OR A BAD SOOR SWITCH--THIS REPAIR WOULD NEED A TECH--TUNICA
Oct 30, 2008 | Danby DMW119 Microwave Oven
Estate TMH16XS 1000 Watts Microwave Oven Logo
32 people viewed this question
Top Estate Microwave Ovens Experts
William Miller
William Miller
Melissa Martin
Melissa Martin
Are you an Estate Microwave Oven Expert? Answer questions, earn points and help others
