Question about Dishwashers
The latch on the soap dispencer is not opening during wash. Ther is a test to check it do you know how to test it?
  • Dishwashers Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Mar 19, 2011
SOURCE:
The machine stops with 21 minuites remaining the pump is running a clicking noise seems to be coming from the soap dispencer have taken dispencer to bits cant see any stripped teeth any ideas?
See if there is wiggle or play in the tub basket. Open loading door put your hand at the top of basket close to the opening and check movement. There should be no play.If there is water in tub when it stops check the drain hose between tub and drain pump for foreign objects. Let me know.
Jan 11, 2013 | Washing Machines
Tip
Ddo mean
soap dispencer open... or on side of soap dispencer have small magnet not on positionor misplace
on Aug 05, 2010 | Washing Machines
Thanks for your help. I have a Kenmore Model # 66513782K600 the main soap dispencer did not open during wash cycle can you steer me down the right path to complete repairs. Thanks again Ken.
heatman101
Apr 24, 2011 | Dishwashers
Soap dispencer does not open during operation
make sure the dispencer is clean from any kind of build up,or simply change out the dispencer
Mar 13, 2010 | Dishwashers
Dishwasher - soap dispenser won't open while washing dishes
A simple was motor is used to open that.
This video shows how to change a door latch but the dispencer basically does the same thing. HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
Bosch dishwasher dispencer will not close
Sounds like the actual dispencer mechanisum is worn or faulty either the latch or the catch you can usualy buy the whole unit to replace this, all this does is keeps the tablet in during the initial pre wash then adds the tablet during the wash after 5 mins open the door and drop the tablet in it will still work the same and save cost
Nov 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap door latch
clean out the soap latch area with water and try using liquid detergent.
failing that, you need to replace the latch.
for the question from 'guest', the wash arms not spinning relates to either a build up of minerals or a pump that is not pushing enough. clean the unit with a mineral deposit remover, and then run a few loads with just water. clr might do the trick, but check the label for conflicts with the materials in your machine.
good luck
mark
Dec 13, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Lg tromm soap dispencer won't open
nothing to lock it fully closed......pull harder!
Jul 21, 2007 | LG WM2077CW Laundry XL Front Load...
Dishwashers Logo
76 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
