Question about Hoover HF712 Front Load
Hi, I have a Hoover Echo WB120 washmachine. I had a flood as a result of laundry I washed, so I took the top off to see what happened. An intake hose which went from the inner solenoid (there are 2) to the back of the drum above what looks like a manifold with a pump attached above left, had come free. I reconnected it, and my next wash I left the lid off. When the knob in front hits the "electric wall outlet" looking symbol between 7 and 8 on the knob, that hose burst off again from the high pressure water coming in. Looking into the manifold, it appears there is no opening to take that water in, but that is where this hose goes. What's the cause of this? There is no blockage in the manifold caused by buildup, it's just hard plastic. Why is that blocked off, and what's the solution to this problem? Thank you. Tom - telf_gliding@yahoo.com.
ngfam1
  • 639 Answers
SOURCE: hoover 500 ma top load washing machine manual & specifications
FRIEND,
BUY SPEED QUEEN FRONT LOADER. IT ONLY USES 13.9 GALLONS OF WATER PER WASH!!!!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
abhishek33
  • 1239 Answers
SOURCE: Hi,Ihave a hoover hnf 7167
hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
thank u................
Posted on Sep 12, 2008
ginko
  • 19396 Answers
SOURCE: Hoover HW120M
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
Posted on Oct 16, 2008
JR JR
  • 116 Answers
SOURCE: Hoover AAA 160 Washer error code 4
PLEASE INSPECT DOOR BOOT (RUBBER DOOR GASKET) IF NOT CAN BE FILL VALVES NOT COMPLETELY TURNING ITSELF OFF ,,, IF ALL LOOKS GOOD REPL/ PRESSURE SWITCH
Posted on Nov 30, 2008
SOURCE: Error message EC03 appears on cotton cycle after 5 minutes into wash
I found the basic instructions that came with the washing machine and found that you need a screwdriver to undo a screw to remove the filter cover. I then gradually released the filter cover to empty the water out of the machine in small quantities into a shallow tray. I was then able to remove the filter and clear it of 2 x 20p pieces and a load of gunk. I then removed the 'washable' floormat from the drum as the rubber backing from the mat was crumbling and probably not helping the filter. Filter cleaned and cover screwed back in, mat in the bin, and everything working fine since.
I did try ringing the customer support number and after pressing loads of keys to select appropriate options; confirming my address, postcode, name, date of birth, email address, mothers maiden name, what the kids had for breakfast etc, I was allowed to ask how to get the filter cover off. Apparently this is a technical query and would involve arranging an engineer to call. I declined this very kind service option and opted for a screw driver, common sense and a positive attitude. Worked for me! No blood shed, a tiny bit of sweat whilst trying to get through on phone, and only tears of joy when I fixed it all by myself.
Posted on Jun 02, 2009
My Echo SHC-212 floods out and will not start. Even with no choke and throtle wide open it will still flood cylinder. I have good spark.
Check your choke prime bulb and carburetor lines - sounds like its clogged and gas is barely leaking into flood the cylinder
Jan 25, 2013 | Echo Garden
Install 800RL
It is best that it drains into a freestanding standpipe that connects to the main drain line out of the house.
May 11, 2012 | Hoover Washing Machines
HOOVER WDYN854D WASHER DRYER MANUAL
Please check these links :
www.hoover.co.uk/products/18/laundry/21/???washer-dryers
www.laundry.manualsonline.com/???manuals/mfg/???hoover/???hoover_???washerdryer_product_???list.html
Sep 30, 2010 | Washing Machines
Door of my Whirlpool awz410 1000 does not lock after putting in laundry for it to start washing?anyone knows?it used to lock after closing but now just doesnt lock and my laundry is pilling
I took out the filter in my whirlpool AWZ410 and cannot get it back in now. It just does not lock home. If I use the machine it floods out through the filter.Any suggestions please?
Apr 23, 2010 | Whirlpool AWZ410 Front Load Washer/Dryer
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
User guide for hoover performa eco 1200
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=10
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
Mar 26, 2009 | Washing Machines
I am looking for the instruction manual for the hoover performa eco wb120 washer dryer as i cant seem to spin my washing which is stuck in the machine
My partner fixed this problem by taking the machine back out and found that the connection to the water outlet pipe under the sink had a buung left in so after it was removed my machine drained
Mar 22, 2009 | Hoover Washing Machines
Calypso washmachine
you have a flood condition,,or overfill,,we must get rid of the water it seems the pump cant do it,,also it can be tripped or make this display fl if to much suds are in unit ..press stop than cancel and it will clear...than put unit in drain,,if water doesnt drain we have a drain problem that caused the fl error..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Hoover HF712 Front Load Logo
150 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
