Printer will not respond, and resume light continually flashes window says wrong cartridge and removing replacing does not solve problem
    Master:
  • 623 Answers
Make sure the cartridge and model of printer is compatible
Posted on Aug 02, 2008
    Master:
  • 382 Answers
This is actually a Catridge mis-match problem..Please Try to hard reset the printer..Jus leave the printer unplugged for 4-5 hours then replugg it n try then..But also please post back here with your model for more appropriate solution...Thank you!!
Regards!!,,,
    Brigadier General:
  • 3,614 Answers
What model and type of your printer, please provide some more info.
thanks
The light above the Start/Resume button flashes continuously. Buttons do not respond when pressed.
If you've got two printer heads (cartridges) try removing one, check flashinf replace and remove second, check flasing
If stops flashing, the problem is with the electronic circuir of the cartridge and you should buy a new one
Also, read info for more tips:
Blinking Lights on the HP Deskjet F4100 All in One Printer Series
Blinking Lights on the HP Deskjet D4260 D4263 and D4268 Printer Series
Aug 02, 2015 | Office Equipment & Supplies
Canon MP560 Gets error code 5100
Hello and Welcome
Error 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
If the problem exist then then go to Canon authorized service facility for repair. You can also get support by Canon by phone, at 1-800-OK-CANON (1-800-652-2666)
Further assistance i am here to help
Please click on Four thumbs which are given below to this solution "if it is helpful"
THANKS & Keep Using Fixya
Mar 13, 2011 | Canon MP560 All-In-One InkJet Printer
Red on print is coming out pink
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If issue still continues:
  1. Verify that inkjet paper is loaded in the paper tray.
  2. Press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes green. The On/Off light continues to flash during the cleaning procedure.
  3. When the On/Off light glows a steady green, press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes, then wait for the demo sheet to print.
the printhead for your printer is in need of replacement. Contact Kodak
Best of Luck
Nov 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Not all the colors print
Best of Luck
Nov 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Poor black print quality black prints greenish grey
Best of Luck
Nov 16, 2009 | Office Equipment & Supplies
Resume light continually flashing, will not print
I had a similar problem with my Photoshop 7150. I tried lifting the latches up on the two print cartridges and then replacing them and the printer came back to life. Don't know why this worked or whether or not it will solve your problem, but, who knows, maybe it will. Good luck.
Dave
May 16, 2009 | HP Office Equipment & Supplies
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have a HP deskjet 6949 series printer. I have had it for three months. My problem is that lights on the from panel(power button light, resume light and print cartridge status light) are blinking...
Power, Resume, and Print Cartridge Status lights are flashing in unison The printer might need to be restarted.
  1. Press the Power button to turn off the printer, and then press the Power button to restart the printer. Proceed to Step 2 if the lights continue to flash.
  2. Press the Power button to turn off the printer.
  3. Disconnect the printer power cord from the electrical outlet.
  4. Reconnect the printer power cord to the electrical outlet.
  5. Press the Power button to turn on the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 22, 2008 | HP Office Equipment & Supplies
PRINTER PROBLEMS
i want programe for aprinters c3100
Aug 02, 2008 | Office Equipment & Supplies
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
35 people viewed this question
k24674
jasbo
jasbo
