Phone not charging. Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
There is a possibility of it working again but water damage does alot of damaging things to phones. The best solution is to take the battery out and don't use it or try to charge it for a few days. Let it completely dry out and it might work but chances are slim. No matter what you hear or read do not place it in the oven, dry it with a hair dryer or even place it in rice. Those things will actually cause more damage to your phone.
Killa Boy - We need a little more information. Has it worked before? Have you tried a different charger or battery? Was it dropped in the toilet?
Zelk - It sounds like your battery is dead. If you have a friend with the same phone or similar, try swapping the battery and see the results. You can find batteries for most phones under $5 on eBay.
the mainboard is gone and have to either be replaced or taken to a mobile service center close to you and hvae them use special equipment to revive it.
Sounds like it is done for, yes. I know a way to save electronics if they are dumped in water, but it requires to fill it with water replacing fluids. Putting it in pure alcohol right away (remove battery first) might save it, as ir should replace the water and then evaporate completey when you take it out.
Some contacts have probably corroded in your phone, so unless you are (or know) a repairman of electronics you'll probably need a new phone. :-/
MJM0103,
If you want to do a manual reset on your phone, it is something you can do.
This is how you do it.
Press Menu
Goto Settings and press select
Goto Initial Setup and press select
Goto Master Reset and press select
If it asks for a code, press 0000000
It will then restart and will power back on just the way you bought it.
Let me know how it works out for ya.
John
does it charge when its not on charging...if it does then its not the speaker...check the settings because if u press the 1'st button on the left side..it can change the setting for ringer type
