Question about Hoover AAA160 Front Load Washer
My hoover soft wave maxi 1600 that stops on spin and the intensive wash button starts flashing,any help please
  • 1 more comment
  • steve walters Mar 19, 2011
    Thanks Daniel
    It flashes 7 times if it makes a difference,sorry forgot to mention this in the original question...
    oh,that dosn't sound good!
    The drum spins freely by hand and it starts to spin(about 3 seconds)stops,then tries again for about 3 seconds then stops,then flashes...
    Thanks Daniel
    Would the fact the drum spins freely by hand and when i try the spin cycle it does actually spin for 3 seconds,stops and then spins for another 3 seconds help point to the exact fault,i'm very confident in carrying out a repair but would like to get it right first time...
    Thanks
    Steve
  • 4,323 Answers
Hi
Two things can cause this issue...first when the washer is unable to drain completely it won't spin, to solve this you can take off the bottom front panel and then clean the drain pump assembly. If the water is draining fine then the issue can be with the door lock assembly and should be replaced. If the door lock sends signal to the control that the door is not closed the washer won't spin. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 19, 2011
  • Daniel Scott
    Daniel Scott Mar 19, 2011
    That's
    fine....7 blinks means Motor jammed / drum
    shaft jammed / techno generator fault and is not a DIY repair.
    Hope this
    Daniel
    That's fine....7 blinks means Motor jammed / drum shaft jammed / techno generator fault and is not a DIY repair. Hope this helps...please post back for further assistance.
    Daniel
  • Daniel Scott
    yup it can be a motor jammed or tachno jam fault
Hoover wash-dryer 110 soft wave It doesn't centrifugate. I would imagine that I have to clean the filter, but I cannot find the filter. Thank you beforehand for your help. Christina
hi christina,,,its dont centrifugate???????? hmmm! do you mean spin?
or it dose spin,,, but dont pump out? if its not spining there is a program fault,,,or motor fault,,,,if it dont pump out,,,thats a pump fault,, program fault or a blocked filter,,,the pump has its own motor,,,however if there is a program fault that could cause the pump to fale to pump as well???
my brain hurts now!
Aug 07, 2010 | Hoover AAA160 Front Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Machine washes o.k. but does'nt spin dry (hoover soft wave auto - washer 1000 )
If you have not already done so, I suggest you remove the motor, and check the brushes for wear.
Please rate my solution.
Thanks.
Oct 08, 2009 | Hoover AAA160 Front Load Washer
Washing machine wont go into full spin
was advised could be bushes so replased them works a treat thanks
Feb 07, 2009 | Hoover Washing Machines
Instructions for Hoover Washer Time 160E
i have a hoover soft wave maxi 1600 7.5kg AAA it spins and empty's and sometimes it don't what could be the fault
Nov 23, 2008 | Hoover AAA160 Front Load Washer
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
My hoover washing machine 1400 spin 8kg hd vision hd
Hi On my washer when I press the start button when allready in opperation all the lkights flash and it stops as this second press of the button pauses the machine and need the start button to be pressed again to restart the machine
Hope that is cleas and helps
Angela
Jun 22, 2008 | Hoover H130E Front Load Washer
Hoover AAA160 Front Load Washer Logo
190 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
