Question about Karcher 2500 PSI Pressure Washer
Karcher 2500 with Honda GVC160 5.5 engine. The carb is clean but it lopes unless the choke is partially closed and then it is better. Gas flow seems OK. Starts OK. When holding the governor it runs smoth. Any ideas?
    Sergeant:
  • 259 Answers
Make sure the governor linkage is clean and works freely. A lot of times when you put a load on the machine, use it it stopps the fluttering.
Posted on Mar 19, 2011
Testimonial: "It is lopng pretty bad and will stop if let alone. This machine is about 2 years old and as I recal it started running rough in the middle of washing "
When using the pressure washer it doesn;t kick into high pressure mode or it won't stay on high pressure. what causes this? the motor seems to run fine.
Posted on Jul 08, 2011
Engine lopes 21.5HP OHV Inteck Briggs&Stratton How do I correct this LOPING problem? If I disconnect any one of the two spark plugs while the engine is running it smooths out. I had removed both the Choke...
It sounds like a dirty carburetor. The carb needs to be removed and cleaned. The loping problem you speak of is a tell tale sign that something is partially blocking a jet or passage in your carb. If you are not sure of how to do it, bring it to a repair shop. To set choke cable, you want choke valve wide open when lever is pushed in and valve closed when lever is pulled/ There should be a screw you can loosen to move cable forward or backwards to adjust. Throttle cable should be snug at low idle when lever in bottom position. There should be a set screw for low idle already set if it hasn't been adjusted yet. Same process to adjust this cable, watch that throttle valve opens completely when throttle lever is all the way up. Good luck, hope this helped.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 08, 2013 | Craftsman Garden
Have a Honda 1000 generator and it lopes even after it warms up. Moving the choke lever closer to choking stops the lopping but that does seem right. Sounds like it is isn't getting enough fuel but not...
By loping, assume you mean surging? I fixed that problem on my larger generator by making sure the fuel tank, fuel lines, fuel filter, carburetor, bowl, etc were all clean and free of contamination, old/varnish, jets clean, etc. I used spray carb cleaner very carefully and compressed air, and seemed to get most of it, although they do sell cleaner kits with those wire sets that work better.
Nov 11, 2010 | Electrical Supplies
Honda GC 160 Engine, I had the carb replaced about 1 year ago, now its doing the same thing. At first it wouldnt start at all, I cleaned the carb, then it started would speed up and die. I then took the...
This really sounds like a carb problem, good to hear that you are taking the carb all the way off and soaking it, this is the best way to clean a carb. I don't think it would be the fuel pump, they either work or they don't. I would check the governer springs and linkages, if one of these is hung up on something it would cause the problems the you have identified. Also, when you re-install the carb make sure that you have all the gaskets installed, it is easy to forget one and that will cause the engine to **** air and make the whole engine run like ****.
Oct 21, 2010 | Karcher 2500 PSI Pressure Washer
Honda engine will not start,,,new plug, new gas, new oil
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
Jul 06, 2010 | Karcher 2500 PSI Pressure Washer
Pressure washer with Honda Engine GC160 only run with choke fully closed.
The carb is clogged. It needs to be cleaned, or replace. Keep in mind some of the carb passageways are as small as a human hair so they are difficult to clean which is why I mention replacing. You can try using carb cleaner etc in the gas, but I don't think it will work if you need the choke that much.
Apr 29, 2010 | Karcher 2500 PSI Pressure Washer
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
May 04, 2009 | Karcher 2500 PSI Pressure Washer
% hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
Nov 02, 2008 | Karcher 2500 PSI Pressure Washer
Choke needs to be on all the time
your problem is in the carb. for some reason there is a stoppage or clogg in the venture opening that feeds the main passage to the manifold. that is the little pipe connecting the carb to the engine.the choke being on causes the engine vaccum to **** gas from other resourses in the carb to run. also check to see if throttle butter fly is moving freely.there may be a defect with the carb and they will have to replace. running the engine with choke on causes it to run rich and will foul the plug eventually . also not good on gas . will use way more than it should. also co2 level way up.
May 21, 2008 | Karcher 2500 PSI Pressure Washer
Pressure washer wont run unless choke is on
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
May 12, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
964 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
