Question about Whirlpool WFE371LVS Stainless Steel Electric Range
How do you get to hidden element on whirlpool wfe341lvs oven?
  • 827 Answers
Hello John,
Open the lower drawer slightly. There are 2 screws on the side panel, where it meets the back panel. Remove those, and slide the entire side panel (the right side as you look at the front of the stove) slightly forward, It should now have released from the little latches, and should flop down. Remove the insulation out of the way, and locate the element bay. It should have a couple of screws securing everything.
Posted on Sep 15, 2011
How do you remove the moulded Hidden Bake Element from the inside whirlpool ceramic range accubake system
first, remove power from the unit before doing ANYTHING! second, remove the back cover of the machine, this will expose another smaller panel with 4-6 screws in it running along the bottom edge across the back. after removing the screws you will have to gently BEND the panel down until you can see the wiring leading to the hidden bake element. cut the insulation covering the back of the element... be sure new element is placed in the exact location of the old one to avoid shorting the bake terminals to the metal cover, then reverse the removal process...
Apr 26, 2016 | Whirlpool 30" Self-Cleaning Freestanding...
Gr673lxss 1 how to find hidden bake element
Kyle,
Usually what they mean by "hidden" element means that the bake element sits in a recessed part of the oven cavity. You only have one bake element and one broil element in the oven. Hope this helps.
Mar 13, 2015 | Whirlpool Electric Range
LOCATION BAKE ELEMENT KESH307HBS4
This model has a hidden bake element located under the oven cavity. This is either accessable by a removable panel in the bottom of the oven or must be accesed from the back of the stove by removing the back panel and several screws. A diagram of the oven etc should be shown at either the searspartsdirect.com or appliancepartspros.com
Nov 29, 2012 | Whirlpool GY396 Electric Kitchen Range
I have a whirlpool gr448lxps-1 range the oven will not go above 200 the control panel works and the temp changes but the oven will not reach 350 tomp element works as it gets hot the hidden bottem element...
Most of the time the replacement instructions will come right with the part...not to worry though once you get it you will see easily how it goes... it is easy to do...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 16, 2010 | Whirlpool GR448LXPQ Electric Kitchen Range
How to get access to bottom element (not visible modle) to replace ir?
That model is not shown as hidden bake but the bottom would have have to lift up to uncover the element .
Nov 19, 2010 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Range GR563LXSSo Oven doesn't come up to temperature. How do you get access to the hidden bake element to check connection and voltage?
Hello- Access is thru left side panel (from front).  Unplug oven and move out for easier access. Remove panel and find cover for element under insulation. Be careful- fiberglass dust and sharp edges!  Insulation needs to be carefully pulled back enough to remove cover and element.  This is where most techs get sloppy-  Insulation should look just as good after you finish so take some time to do it right. Please acknowledge this posted solution if helpful. I have more info if needed.- Thanks- Ed
Mar 24, 2010 | Whirlpool Ovens
I need to replace my bake element on the bottom of the oven. I have removed the plate but do not know how the wires disconnect
they are just a push-on spade terminal,pull them off replace the element and carefully push-on the terminals to the element
Nov 18, 2009 | Whirlpool GSC278PJS Oven
Need to replace hidden bottom element on whirlpool gold GJP84900 how do i get to it
OPEN OVEN DOOR, LOOK FOR SCREW HOLDING ELEMENT TO BACK PANEL, TURN OFF POWER, REMOVE SCREWS, SLIP OFF WIRE EACH SIDE.
BOTTOM BAKE ELEMENT, TOP BROIL ELEMENT.
Oct 25, 2009 | Kitchen Ranges
I am looking at buying the new hidden heat element
It sure can. Whirlpool has some wonderful appliances and their ovens have a very large capacity for your Thanksgiving turkey or what ever you cook. The best of luck to you and enjoy your huge new 30" oven.
Sep 07, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Replacement of bottom oven element for Whirlpool oven
its only screwed in to back wall no???if screws rusted well then drill htem out.hidden bake elemnet??hidden under oven cavity??in that case right side wall of unit comes off( a few screws down back side of panel and it removes from the side.(shut power first this element is always live!!!!!!!
Feb 24, 2008 | Ovens
Whirlpool WFE371LVS Stainless Steel Electric Range Logo
105 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
