Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
WATER DISPENSER, OUR GE FRIDGE IS 2 YRS. OLD THIS MONTH, THE WATER DISPENSER NO LONGER SHOOTS OUT WATER IN A HARD STREAM, IT JUST BARELY TRICKLES, AND THEN GOES TO A DRIP, I HAVE NEVER CHANGED THE WATER FILTER, COULD THIS BE THE PROBLEM, I TOOK IT OFF AND LOOKED AT IT, NOTHING LOOKS LIKE IT COULD STOP UP ON IT. WHAT DO YOU SUGGEST, I ALSO TOOK THE HAIR DRYER AND HELD ON THE LINES BEHIND THE CRISPER, BUT THEY WERE NOT FROZEN, ANY SUGGESTIONS?
  • pnagow Aug 30, 2008
    Water is definitely flowing slower out of water dispenser. I changed the filter, as we do everytime the change filter light comes on, but the water flow has not changed. I even changed it early to see if flow inproved and it did not.
    Nothing has changed about the location or adjustments.
    Any ideas?
  • BENJASURF Sep 10, 2008
    WATER DISPENSER PROBLEM
    GE GSH25JSTA SS: I JUST REPLACED THE FILTER AND I DON'T GET ANY WATER COMING FROM THE WATER DISPENSER..... HELP ITS ONLY A YEAR AND COUPLE MONTHS OLD.
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE!
Posted on Oct 18, 2008
I CHANGED THE SMARTWATER FILTER, AND NOW THE WATER FLOWS AS IT DID WHEN THE FRIDGE WAS NEW, IT ALSO WILL MAKE MORE ICE, THE INSTRUCTIONS IN THE FILTER BOX, EXPLAINED THAT WATER FLOW COULD BE RESTRICTED AND ICE MAY NOT MAKE AS OFTEN WHEN THE FILTER IS OLD. SO I WILL BE CHANGING THE FILTER AT LEAST EVERY YEAR,
Posted on Aug 03, 2008
What, other than clogged filter, causes water flow blockage in Whirlpool ED25TE?
FYI - Mine actually froze the water in the line.. had to remove the water filter, turn off the ice maker, pull the fridge away from the wall..remove the line from the fridge connection..laid it outside for a few hours until I could blow through it.. re-installed ..all ok..
Jun 08, 2017 | Whirlpool Refrigerators
Fridge and freezer suddenly not working only 1.5 yrs old
I guess the culprit in this case is the compressor.. Do you hear a sound when you are near the refrigirator.. it will be like a fan rotating at a high speed...
Mar 07, 2008 | GE GSL25LGTBS 25.4 Cu. Ft. Side-By-Side...
I have a GE Profile side by side with water and ice in the freezer door, it is about 3 1/2 years old. The water was barely coming out of the dispenser, I changed the water filter and it is not any better -...
We had this problem on our own fridge at home. it turned out the plastic lines which feed these appliances liable to fill up with lime and calcium which will restrict water flow. take a look at getting a new line.
something else to look at. is the tube getting kinked when you push the fridge into postion?
let me know if this helps. davcol47@hotmail.com
May 08, 2010 | GE PSC23NSWSS Profile Counter-depth 23.2...
Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
Monogram water flow problem
common low flow is a kinked line or a bad water valve, the solioid valve has a filter that may be dirty. then go from there
Jun 11, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
521 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
