Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
DUE TO EXTERM WEATHER, MY LCD TV SHARP LC3242U STOPPED WORKING. CAN YOU ADVISE ME IF I NEED TO REPLACE THE MAINS FUSE? if yes what is the fuse no. amperage / slow' fast blow? Many thanks Aaron
    Genius:
  • 1,126 Answers
If your are not getting anything, it could be a fuse, but if the led is lit, the you need a power supply.
Posted on Mar 19, 2011
Tv hit by thunder
Do you use an outside antenna? If yes the main board is shot. There is a fuse on the power suppl board inside the TV. It may be burned.
Jun 18, 2014 | Sharp LC-32M400M 32" Multisystem LCD TV
I have an update on my problem with the backlights not working. I replaced the Main board with what I thought was the correct version but it is not. With the new Mainboard installed the backlighting c
3x flashing LED usually points to a main board problem. And yes many Sharp LCD TV's have several different versions of main boards for the same model #. And as you found out, they are not interchangeable. You need to return the replacement main board and get the exact part # as the original main board.
Sep 04, 2012 | Sharp AQUOS LC-46E77UN 46 in. LCD HDTV
I have a sharp lcd 32 inch it stopped working, it won't turn on.
Try to check the main line and if its ok proceed to the power chord then to transformer or the fuse and you look it they are fine look for a technician to check your tv.Choose a better technician near from your place.
Nov 06, 2011 | Sharp Aquos LC-C3234U 32 in. LCD TV
I have a shard aquos LCD tv. When I turn it on, everything comes on for 1-2 seconds, then the screen goes black. If I turn it on and off again (about 10-15 times) the same thing happens. Eventually, the...
When the tv have this problems dose the tv Power and OPC lights indication flashes together?Yes,than the tv main Tuner signal board it is dying and shorting out.Happen to my Sharp Aquos 46' tv many times but it only take about 2 or 3 off/on to get the tv backlight lite and the tv to work.U can do some mechanicals work wright?Like take thing aparts and putting it back togther again?Yes?The tv Tuner signal board that the board where the tv incomming broadcasting cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.
Aug 18, 2011 | Sharp Aquos LC-32D40U Television
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
Audio on sharp aquos lcd went out 2 years old seems problem is rampant and consumers should be reimbursed for repair by sharp.they need to stand behind their product cost to repair 350.00
Sharp is taking care of this for customers even if you are out of warranty due to a mistake on how they made the tv. All you have to do is call Sharp at 1-800-237-4277. It took my repair in NYC (MTZ electronics) shop 1 day to fix the issue. MTZ electronics even applied 2 firmware updates that all the D6U tv's need to avoid other known issues with the lcd in the future. These firmware updates are for the main cpu PH1UU112 and the monitor MD1UA104. I am so happy and am loyal to Sharp for their fantastic customer service. I also want to thank MTZ electronics for having the best customer service and being the best repair shop I have ever been to. Good luck everyone
Aug 03, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Damaged the LCD - Sharp 46 in. LCD Full HD Television, AQUOS®
Yes it is possible to replace the panel. I would suspect that it is cost prohibitive however. I am willing to state that the cost of the panel will be close to if not more than the cost to replace the TV.
Sorry about the bad news.
Dan
Feb 02, 2009 | Mitsubishi VS-5076 50" Rear Projection...
Have an Aquos Sharp 32" 1080p LCD TV and the power went out in the house. Now the TV will not turn on, when I try the power indicator light blinks green repeatedly. Read the manual no help there....
This sounds like a problem that only a repair person can specifically point out.  It could be anything from a fuse to the "engine".
Try to find a local "authorized" repair person to give you a free quote with no responsibility on your part to get it fixed as TV repairs can cost 50% of what a new one would or what a working used one would.
Also, I'd recommend to NOT overload your electrical outlets and to not use without a surge protector (a real one).  If there is a storm or it's very windy,  try keeping not only your monitor for your PC off, but also your TV (unless you need it for emergency reasons).  Also, try getting a used battery powered cheap small tv with a digital converter box if you need to monitor the tv during an emergency.  Also, get renters of home insurance to cover the costs of weather related damage.
Last thing... be sure that any "extended warranties" offered by your local electronics store will cover the cost of any weather related power outages.  If so, it may be something to look into purchasing, although I generally advise to not buy into "extended store warranties".
OK, one last last thing... check the warranty with the manufactuer (SHARP)... If it's under warranty, tell them it's not working and you don't know why, so you need a replacement.
Good Luck! thomseye
Dec 13, 2008 | Sharp Televison & Video
Sharp aquos lc -32da5u
Probably needs a new main unit or power supply board replaced. Most times is main unit
Jun 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Goodmans 27 inch LCD
Sounds like the power surge may have blown the fuse in the TV. You can replace the fuse and see if that works. If not, more damage to the power supply unit may have occurred.
Jun 09, 2007 | Goodmans W280NS Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
191 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
