No hot water when switched on there is power at the shower terminals
  • 43,501 Answers
I believe you are talking about an electric shower head...
The most common thing is the heating element going bad...
Check for power to the heating element...
heatman101
Posted on Mar 19, 2011
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
I have power to the shower power to the switch inside the shower but no water comes out
not familiar with powered showers please make and model bit old fashioned EH use 2 handles one on hot and one on cold
Jan 30, 2015 | Home
Shower is cold when switched on
When you turn a shower on the hot pipes are filled with cold water, it takes a while before the hot water gets from the water heater to the shower.
Jun 20, 2010 | Home
No hot water from electric shower Berry magicoal Action 850
you need to replace the element probably. you have a short which is a wire touching sometimes then it gets away
May 10, 2010 | Home
No hot water
Check your fuse/breaker, should be a rcd switch. Depending when the shower was installed the fuse/breaker may be separate from the main fuse board, if it is an rcd switch it should be between 30A and 40A rating. If it is still fuse wire or cartridge fuse it should be replaced by residual current device.
Remember to turn the shower off in the bathroom before returning power to it.
Hope this helps
Apr 10, 2010 | Home
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Electric shower is not getting hot
Locate your electrical panel box, find the breaker for the water heater, turn it off then back on, locate the water heater. Fins the powere disconect. Sometimes they are a simple pull disconect or switch, sometimes they are another breaker or fuse.
Check the fuses or flip the breaker if aplicable.
Do you have a volt/ohm meter?
Dec 06, 2008 | Home
Cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
Oct 05, 2008 | Home
Bosch Tankless HW Heater...Hot water flow becomes cold then hot again during shower. Have had only Bosch plumber in area out numberous times but never fixes the problem.
You are using a low flow shower head. you probably own the 250/2400 they have activation rate of .8gpm. If your shower head is low like this, your unit will deactivate. Higher flow shower head is a fix, or pull the aerator out of the shower head you have now might help.
Sep 23, 2008 | Terminator Aquastar 125FX Tankless Water...
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
