Question about Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch
Replacement bracelet for Tag Heur 6000 series, model #WH1151.BD0678
My Tag Heur is 8 years old, the bracelet broke, and 2 jewelers said it could not be repaired...it needs replacement.
But the Tag Heur replacement is $800, which I cannot afford.
Is their an aftermarket band/bracelet, in stainless steel, that would fit this watch?
Thank you.
  • 10 more comments
  • nancygarryh Aug 19, 2008
    Mine has broken the stainless steel link in the band twice. They want $1900 for a replacement band. This is a design fault and Tag Heuer should stand vbehind this watch as it was one of the most expensive watches they made in 1990's
  • avangeles Aug 20, 2008
    the bracelet of my Tag Heuer 6000 series, model #WH1112-K1 broke and now I need to pay about $800 for a replacement. This is just ridiculous!
  • Anonymous Sep 03, 2008
    Yes, This has just happened to me, I love this watch, but this should never happen. I am waiting to hear what this will cost me. When I got it cleaned, I believe the person that did this took every link off to re-buff it and this caused the wear. Very aggrivating, since I spent nearly 1600.00 on my first nice watch 7 years ago.
  • TAG Regrets Nov 16, 2008
    My wife and I each had exactly the same problem. We've sent the bands off to the authorized repair facility and also shopped them around to jewelers with the same answer. TAG bands are (or were then) ****, it's a known problem, they won't do anything to fix them.
  • awhicker Nov 27, 2008
    A jewler sent my tag out to them and they replaced the pins...thinking the bent pins were causing the problem. That was 8 years ago. Now it broke again...and another jeweler made the dimples that hold the pins in deeper. but it broke again and he said he must have missed one. Well it again broke...haven't gone back...but it was only $19
  • thebigboum Jan 14, 2009
    I Have the same probleme they tell me 1400$
  • diyscar Jan 23, 2009
    Ladies 6000 series - NOT made to last!!
    I bought this watch in 1995, and it gave me 10 years 'every-day' use. All would be great if only the bracelet was made better... as anyone who has this watch will know, the parts are very intricate and clever(?!), and over time, metal wears away metal. But it came with a 1 year guarantee (wahoo, thanks Tag Heuer). I love the brand, but the company refuse to accept responsibilty for a bad design, and that in my book, puts them way below barely competent.
    Jewellers won't touch it, you can't replace with a normal strap (because of the way its fixed to the watch), so i suspect there are many 6000's in pieces stuck in a drawer somewhere. I'm glad Brad Pitt (and others) made lots of $ for being brand ambassadors, because their products ****, and the company has no honesty or courage to admit they cocked up on this one.
    If anyone has a solution for a fix for this watch, it'd be great to hear from you..
  • BushManNJ Jan 29, 2009
    I have the same problem. The bracelet is broke, is there an aftermarket?
    Thank You
    JOE BUSH
    Cell-609-335-0775
  • Anonymous Feb 12, 2009
    I've had my 6000 medium size since 1994 and my 3rd leather strap is now broken. These straps are so expensive that for the past five years I have anly been wearing it occasionaly, but still the strap has given out.
    Also my TAG is inaccurate. It looses about 5 mins every 48 hours. I've had it serviced by TAG (mega expensive) and by an independant.
    I thought that chronometer actually meant the watch was very accurate.
    Not a chance in hell I'll ever be knowingly buying another LVMH product. They don't give a ****! Got your money, now go **** yourself.
  • Anonymous Apr 18, 2009
    I would be interested in buying a couple of links for the 6000 mens bracelet, anyone up for that ?
    We lost the replacement links and they are prohibitively expensive to replace
  • john mac 2 May 15, 2009
    I have the same problem but Tag in Switzerland are going to take a look, seems from my engineering background that some parts in the bracelet are under engineered which needs to be stripped, defective parts replaced and rebuilt.
    Regards,
    John
  • Wendy Sacks May 29, 2012
    Has anyone gotten anywhere with Tag Heuer regarding this problem?
I have two tag 6000. one of the watch bands broke and I found a great fix. look on ebay for a rubber band called for rolex presidents. it fits the tag and the ribbing goes perfectly with the watch style. a easy and inexpensive fix, although you loose the stainless band...good luck
Posted on Apr 03, 2009
Perhaps this replica watch and strap would fit. It's $295
http://www.salesreplicawatch.com/Tag_Heuer_6000_Series_Mens_Watch_WH1153.BD0678.html
Posted on Aug 26, 2009
I put a Formula One Tag stainless band on a 6000 professional chronometer, the sheen is slightly different, but it's a very strong band. Double clasp. You won't break it.Similar in appearance to a Jubilee band. You could buff the band up a bit to a perfect match if yo like. Goes in with pins instead of screws. Fit is a bit snug but it goes.
Posted on Dec 21, 2009
This problem is very common for this watch.
As far as I have been able to determine, there is no aftermarket stainless band available. The quotes I recieved are in line with those noted above, which everone agrees is ridiculous.
My solution has been to use an inexpensive leather after-market band (I bought mine at Jarods). It looks pretty good with my stainless 6000. Not really a solution but at least I can continue to wear what was a very expensive watch.
Posted on Jan 25, 2009
I have the same problem....any solutions yet?  Really maddening!
Posted on Sep 09, 2008
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
This game, you start at the cavern men's age, then evolve.The goal of the game also differs depending on the level. In most levels the goal is to reach a finish line or to collect tokens. Many levels feature alternate or nonexistent goals for the player. The game controls are shown just under
animaljam 2 ' five nights at freddy's 2' hotmail login
Posted on May 11, 2017
Same thing happened to me with my 1997 model
My solution
I purchased an unused 2006 model from a local trading website called donedeal.ie I got the replacement for 350 euro, took the bracelet and sold the watch minus bracelet on ebay for 210 euro
The total cost of my unused replacement strap was 140 euro, but it did take me 2 years to find the watch
Posted on Jun 21, 2012
Same watch same problem!?
Posted on Sep 15, 2008
Hi
I have a brand new stainless steel band for a tag 6000 full size with pin fixing. It is $450.00 with free shipping. If interested give me a call on 0044 7944774882
Posted on Apr 05, 2009
The bracelet broken from the watch face. Can this be fixed?
You can try taking it to a jeweler to see if they can do a repair on it. But it is most likely that you will have to get a new skeleton case and transfer all of the inner working from the broken watch to the new case. Here again, a job best done by a jeweler because they would have the speciality tools that are required.
Jun 09, 2014 | Fossil ES2790 Watch
Kenneth cole watch
many jeweler have drawers full of spare parts like that. watchmakers too. if you strike out at a jeweler, ask who they use to service their watches.
May 06, 2013 | Kenneth Cole New York Automatic Bracelet...
Links are broken in the bracelet.
Thank you for contacting FixYa.
Most watch companies do not warranty bands, but I would suggest contacting Tag Hauer at this link:
http://csec.tagheuer.com/csec/index.lbl
Best regards. Jewel
If you have extra links from being shortened, that may be of use too. Try a local jeweler for that repair.
Oct 21, 2010 | Tag Heuer 6000 Quartz WH1351.BD0680 Wrist...
Lost spring connector that attachess glasp to bracelet. Where can I purchase one?
I would try a local jeweler first as many spring bars are interchangeble.
If not, I would go to:
http://csec.tagheuer.com/customer-service-centres/home-us/index.lbl?center=8E66BBD1-F0A7-4400-AD32-823491A591B9
Best regards. Jewel
Sep 14, 2010 | Tag Heuer 6000 WH1311.BA0677 Wrist Watch
Where can I find a replacement band for my tag heuer professional series (ladies') watch?
mcdevito75 here, BEST BET, Look for a small watch repair shop in your area for a replacement band, or you may want an orginal band to maintain authenticity, a band straight from Tag Heur can be ordered.
Jul 09, 2010 | Tag Heuer Link Automatic Chronometer...
I need 2 links as i have put on a lot of wheight and cant find my spare ones, can you help?
mcdevito75 here, Hopefully you have a warranty with your watch, Contact Tag Heur by phone / online for these links you may get them at a discount or even for free but they will have to come from Tag Heur to maintain the authentisity of your watch. You can also try to see almost any jeweler in your area for more info.
Jul 07, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
My tag heuer wk 1111-0 has a serial # mb 9169 ; how old is this watch?
mcdevito75 here, The number on the movement itself is the number you need, Look for any small watch repair shop in your area for an estimated age, or you can contact Tag Heur online, try tag Huer watch.com
The folding deployment clasp on the bracelet/strap for my Tag 1000 series ladies watch has broken. Might a replacement clasp from any of the current tag models fit?
The newer straps on TAG are generally wider than the professional series and the cost of a new genuine TAG heuer clasp or bracelet may easily exceed the costof buying an entire watch of that series used.
I recommend searching for an after-market strap/ buckle usuing your case back numbers as the search criteria.
Oct 17, 2009 | Watches
Broken watch band TH 6000 WH1151
This has happened twice to me. First time they said no alternative but to purchase new strap.... £850!!. Second time watch is in drawer and I am so fed up I have not even bothered to take it back again as I know what the answer will be and I cant afford to pay that again!
Oct 05, 2009 | Tag Heuer 6000 Quartz WH1151.BD0678 Wrist...
My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Jul 28, 2007 | Tag Heuer Link CJF2114
Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch Logo
11,740 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
