Question about Kitchen Ranges
Kenmore eletric range replace the temp probe 6months later same problem new one installed today still f30 code any sugestions thank david
  • 827 Answers
Hello Dbs,
It seems that the temperature probe/sensor in the oven has failed. Visit the following site and order a replacement from the link provided below :
www.searspartsdirect.com
Posted on Sep 15, 2011
I have a Kenmore Elite slide in range. The stovetop works fine along with the twist knobs. But the touchpad buttons and the oven doesn't work at all. When i tried unpluging it to reset it, it flashes an...
The F30 error code means the temperature sensor probe is open. First check the wiring, then check the probe. And if necessary, switch to a meat thermometer instead of a sensor probe. F31 is the error for a shorted temperature sensor probe.
Dec 27, 2017 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F30 error code
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Gas range. Oven does not work and F30 alarm displays.
Sep 01, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Just purchased a Tappan TEF326FB and oven will not work. Get an error code F30 whenever press Broil or Bake buttons. top elements, clock, timer all work ok. followed manual instructions but can not get...
After much effort, and thanks to ABSOLUTELY NO HELP from Lowe's (where I bought this range) OR any of the contact numbers their 1-800-# referred me to (ie. SEARS Appliance repair in Californina, Chicago, etc.) or the the local Warranty repair service here (where we were finally referred to - they were "too" busy" to come look at it until 7 days later on June 25),
I managed to find out that the "F30" error code meant an "Open probe connection". and to "check resistance at room temp & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Chck Sensor wiring harness between EOC & Sensor Probe connection". I had no way to troubleshoot all of this or even to know where to look for the RTD probe or the wiring harness hookup. By the time I was able to find out what the error code mean't, I had taken the range back to Lowes where they tried to tell me that they shouldn't take it back because I had bought it a week earlier - even though It sat in the box and was not installed until 7 days after purchased. They finally took it back.
I promptly went to another appliance dealer (not Lowes or Sears) and bought a similar range which worked fine upon hookup. Too much hassle dealing with these folks.
Jun 19, 2009 | Kitchen Ranges
F30 ERR message on Frigidaire Professional Series Range
I am a tech and just had this happen to me, so I can feel your frustration. I have replaced the temp probe, erc, and still had the problem.
Open the back, with the unit unplugged. On the lower right hand side there is a relay, beside the relay there is a "safety T-stat" disconnect from the circuit by removing one wire and read for continuity. If none is detected, replace t-stat and voila... stove works. Much cheaper than erc and probe...
Jun 11, 2009 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
I was the two front burners for an extended length of time yesterday on kenmore range. I got an F30 error code and the over will not work nor can I use the timer or the clock.
Apr 05, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Our kenmore 790 built in oven keeps flashing an F30 code after we turn off the oven, or sometimes when the oven is on, it shuts off and then beeps the F30. I keep hearing it is the RTD probe, but where is...
Mar 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Installed new EOC for Sears Kenmore Elite 790 46609500 oven.
Jan 02, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Stove oven does not workit,s a kenmore stainless steel
I have experienced a f30 code on my oven...I was told to change the oven sensor probe which i did....The code still comes up!!! SEARS IS NOT ANY HELP
Jan 20, 2008 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
