Question about Samsung 46 in. LCD HDTV
I have a Samsung LN46A540P2F flat panel tv. When I turn it on all I hear is a clicking noise about every second or so and sometimes quicker. Ther is nothing on the screen. I have unplugger the tv and it stops but when I plug it back in is start again. Jim
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
  • 157 Answers
SOURCE: TV turns off and on
you have bad electrolytic caps in the power supply---remove power supply replace swollen caps--if you do not think you can replace caps try shopjimmys.com enter model number scroll down to find power supply-if they do not have in stock write down part number then google it to find one
Posted on Sep 15, 2009
  • 195 Answers
SOURCE: my tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Posted on Oct 12, 2009
SOURCE: Samsung LCD TV slow to start
Dont have a solution, my samsung 46 inch is doing same thing. Have you found a solution?
Posted on Sep 04, 2010
  • 12 Answers
SOURCE: Samsung LNT4661FX/XAA 46 in. HDTV LCD Television -
Got to Samsung's support site and fill out a request:
http://www.samsung.com/us/support/service/request
You will be contacted by your regional repair center. I'm located in Milwaukee, WI and was contacted by a repair center in Elgin, IL, which is 60 miles away.
The regional center said they think it probably is a electrolytic capacitor issues, as multiple models of Samsung LCD's have this issue. They have defective (too low voltage) capacitors which will eventually give out. Unfortunately he said my model was not on the list they have for a free fix. He gave me the number to Samsung's Executive Customer Relations department, which I then called immediately. The woman there checked and found that my model indeed was covered - she updated the Support Request, and instructed me to call back the regional repair center.
I called back the regional repair center (immediately after finsihing with the ECR) and got a different person on the phone, and gave them my ticket number from my original request. He said since ECR updated it stating my model was covered they would fix it for free. If it's not the capacitors that are causing the problem I will be charged a 150$ fee, plus any parts required to fix the TV. I agreed to that since my local TV repair quoted me 200$ to fix the capacitor issue alone.
Today is January 25th, they have me scheduled to have a repair tech come to my place January 7th to do the repair.
You can fix the capacitors yourself for very cheap, maybe 20-30 bucks if you don't have anything: soldering gun/solder/flux/capacitors/etc...
I'd just go through the service request path, get it fixed for free and have a professional do it. Total time for me was 2 minutes for the service request, 10 minutes on phone for regional repair center, 10 minutes for ECR, 5 minutes for regional again. The repair is expected to take 15 minutes - most likely they'll just swap out the entire power supply board rather than the individual capacitors. Basically 1 hour of time to save minimally 150-250 dollars. I bet not many people asking to fix this make 150 bucks an hour...pretty simple math I think.
-Ryan
Posted on Jan 25, 2011
Samsung ln46a540p2f
Visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 01, 2015 | Samsung LN46A540 46 in. LCD TV
I have a Samsung Flat screen TV model LN T4071f8 and when I turn it on it just makes a click click click noise and then sometimes it will turn on.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 15, 2015 | Samsung Televison & Video
The tv does not turn on right away, ther are clicking sounds before it comes on
It sounds like faulty capacitors inside the set, this model is known for this problem. Are you looking to repair yourself or just looking for a repair estimate?
Mar 24, 2013 | Samsung LN-T4661F 46 in. LCD HDTV
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
Samsung plasma 50in PS50B550 clicking noise
The clicking could be a loose connecction of the power plug or frrom the main power unit of your TV. Remove your plug and see the ends for burn outs, if so clean and use a different outlet. If not open the set after disconnection and check your main power supply unit for loose connection particularily in the surge protector, the main capacitor, the main drive, diodes or connectors. Wait to hear the sound and use a long insulated rod as a probe to confirm the origin of the sound. Solder or replace the damaged item. Hope this helps . Good day
Jul 22, 2010 | Samsung Televison & Video
Samsung LCD HD TV Model # LN-S4041D > 4 years old - working fine until today - While watching TV, I heard 2 loud beeps and the TV image was lost - initially frozen pixels and some moments later .......
Th clicking is from the power relay. You will have to open it up, the first place to look will be the power supply module, look to see if it has any bad caps with leaking/bulging tops first, caps can look OK but can be bad due to high ESR.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 17, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Goes off & comes back on.. now stays off Samsung model LN46A540P2
This could be 2 things, a main board or a power supply. I have replaced many main control boards on samsungs and it solved the problem. But sometimes it could be the power supply. You will need to test the voltages on the power supply to rule out the power supply being bad.
Jul 11, 2010 | Samsung 46 in. LCD HDTV
Oct 05, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Vizio 42" 1080p HDTV LCD.
This is likely due to heat expansion (turned on) and contraction (turned off).
Nov 19, 2007 | Vizio L32 32 in. LCD HDTV
Samsung 46 in. LCD HDTV Logo
180 people viewed this question
Jerry Greenberg
Jerry Greenberg
