Question about Belkin Basic Wireless Router
Just bought Belkin Surf N.300 (374E) and use it as secured routerbut the range is poor. Using it next room and instead of 12.5 mps I have 3.75 mps wireless. Any possibility to boost the power ? How do I change the name of the device ? Thank you
    Sergeant:
    Champion:
  • 236 Answers
You could use a range extender available at local computer stores.
Posted on Mar 19, 2011
How to reset a belkin router
I will share the information on how to reset belkin range extender
Check the back of your range extneder and there will be showing a reset key at th back
Press the reset button using paperclip hold for 30 sec
Now release the reset key and Restart the range extender
To know more information
How To Setup Belkin Range Extender TechVaidya
Jan 08, 2013 | Belkin Wireless Surf Router (F7D2301)
Can't connect to a second wireless SONOS via Belkin Surf 300
Go to the router web UI and see if is there then grant access to it.
May 26, 2012 | Belkin Surf N300 Wireless N Router
Can u please help me fix this. I bought a Belkin Surf and it wont give me wireless reception
Uninstall Belkin Router Monitor software from the control Panel
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 19, 2010 | Belkin Wireless Surf Router (F7D2301)
I just bought a new Belkin Surf router. We went through all the steps the start-up cd says. But it keeps asking for a security key. Where can we get that?
Hi i got your issue .......
Please try with the following steps ......
Step 1 : Connect modem -Router - Computer ( Wired)
Step 2: On the left under wireless click wi - fi protected setup
Step 3 : Leave the password blank and click on submit
Step 4: Disable it and Click on apply changes
Step 5: On the left under wireless click Security
Step 6 : Enable 64 Bit WEP
Step 7: Type a 10 digit number on the key 1 ( 2 in each box )
Step 8 : Click apply changes
Step 9: on the left under wireless click channel and SSID
Step 10 :Change the Wireless channel to 6
Step 11 : Change the SSID to a different name ( no Spaces )
Step 12: Click apply changes
Step 13: Now Scan and connect to this network ( Wireless )
If problem still presists please contact 24/7 belkin technical support 1800-2235546
Oct 06, 2010 | Belkin Computers & Internet
My Belkin N-1 is very weak. Can't get a signal from one room to the next. Is there a fix or does it need repair?
Try changing the channels on your router... Also, if you have a wireless phone near it make sure that they are using different channels or better to move it away from your router... very thick walls also weakens the signal... try placing it first near your laptop just to check that you can connect wirelessly before you move it away... you might just need an range expander or repeater to boost up the signal
Mar 28, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin adapter will not connect to home network. It says poor signal strength even when I'm in the same room!
hi it is simple to connect to the wireless network using the belkin adapter.
You can switch over to the windows utility. that should work. it does not work then try to uninstall and reinstall the adapter.
Click here for more info
Oct 11, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Very short range
No this is not typical if the Network card and router are just one room away. However electrical interference and walls do impede the signal.
Try moving the Router around to see if the signal improves.
You can also adjust the antenna and pointing it in the direction of the Router.
1. Position your wireless router (or wireless access point) in a central location.
2. Move the router off the floor and away from walls and metal objects. (Such as Metal file cabinets)
3. Replace your router's antenna.
Antennas supplied with your router are designed to be omni-directional, meaning they broadcast in all directions around the router. Upgrade to a hi-gain antenna that focuses the wireless signals only one direction. You can aim the signal in the direction you need most.
4. You can add wireless repeaters. (just the room next door this would be a last resort if all else fails)
5. Change your wireless channel. You may find one that will transmit a stronger signal.
6. Reduce wireless interference
If you have cordless phones or other wireless electronics in your home, your computer might not be able to "hear" your router over the noise from the other devices.. To quite the noise, avoid wireless electronics that use the 2.4 GHz frequency. Instead, look for cordless phones that use the 5.8 Ghz or 900 MHz frequencies.
7. Update your firmware or your network adapter driver
Source:
http://www.microsoft.com/athome/setup/wirelesstips.aspx
Nice diagrams on this web page too.
(Couple items left off as these did not seem to fit your current situation)
Oct 06, 2009 | Belkin Dual-Band Wireless A+G Desktop...
Only connecting localdifficult to get online
Have you install the software that came with the modem ?
Jun 01, 2008 | Computers & Internet
Belkin Basic Wireless Router Logo
145 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
