DEXSI USB LOCK V.1.7.0.0 PRODUCT KEY PLSSSS...
    President:
  • 2,246 Answers
Posted on Mar 19, 2011
What are the names of the buttons on my admire Samsung cellphone
12_13_2012_8_52_41_pm.jpg Front view: 1. Earpiece
2. Menu Key
3. Home Key
4. Back Key
5. Search Key
Side View:
1. Accessory Hook
2. Volume Key
3. microSD (Memory Card) slot
4. USB Power/Accessory Port
5. Power/Lock key
6. Camera Key
Nov 22, 2012 | Cell Phones
Pendrive Transcend 8GB JFV10 error message "Disk is Write Protected"
First
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
However if that does not solve your problem try this
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
Jun 24, 2011 | Transcend (589307) Media
I forgot my security code wanna reset it immediately plsss help.......my imei no-353411044737999...plssss
Hi raval_188,
Please try the following lock codes :
1. 1234
2. 12345
3. 0000
4. 00000
If these codes do not work then perhaps you have set it to your OWN code and forgotten it.
the only way to resolve this issue is that you should take your phone to a nokia dealer shop along with a receipt and ask them to fix it.
I hope this helps.
Jun 19, 2011 | Nokia 2690 Cell Phone
J need refferent key for microsoft office profesional 2007 trial pls can you halp me j need it as soon as posible...plssss
Installation Instructions
1. use VB48G-H6VK9-WJ93D-9R6RM-VP7GT for Office Suits and
HCFPT-K86VV-DCKH3-87CCR-FM6HW for Office Application.
no activation needed, install and use.
Feb 06, 2011 | Microsoft Office Professional 2007 Full...
Licence key
Unfortunately, Fixya does not provide keys as it is illegal. You need to purchase a license for this software.
Apr 17, 2010 | Intel Software SATA RAID 5 Activation Key...
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Downloading drivers of webcam pc-2008m
This should work:
http://www.vimicro.com/english/product/PublicDriver/WIN/DRV_ZC0301PL_070404.zip
Jul 01, 2009 | Umax AstraPix PC200 Webcam
Serial number ng adobe photoshop cs2 plssss......
Hey i found this great new site offering Adobe Photoshop Serial Numbers for all versions, here's the link:
Adobe Photoshop Serial Keys - All versions
I hope this helps...
Oct 28, 2008 | Adobe Photoshop CS2 for PC
Disable usb pendrive,cd rom and floppy in win2003
You can lock the USB drive by editing the registry. So I’ll tell the key name and the value, that you have to create for the restriction. If the key is not present, then simply create it.So here we go:
Restrict Writing to USB Drives:
HKEY_LOCAL_MACHINE\SYSTEM\Current Control Set\Control\StorageDevicePolicies
Create DWORD value WriteProtect and set its value to 1
ALso, please click on the link mentioned below for more information:
http://support.microsoft.com/kb/278295
http://support.microsoft.com/kb/231289
You can also use third party software to lock the USB drives:
http://lock-usb.qarchive.org/
Thanks
Aug 20, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
