Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
My fan and light do not work and I was told that the relay needs to be replaced. Is that true and if so, where can I pruchase one?
  • 2,510 Answers
If neither the fan nor the light work, check that there is power to the fan unit first. If it is remote controlled and there is power to the unit, any relays would be on a PC board inside the fan and will not easily be replaced.
Posted on Mar 19, 2011
2007 town & counrty (3.8) cooling fans staying on
the radiator temperature is broken or cable to it is disconnected ?
if true they are set to run constant the fans to protect the engine from overheating. also check the relay is still seated correctly.
Dec 23, 2013 | 2007 Chrysler Town & Country LX New Cars
Problem: A co-worker has a 1999 Audi A6 Quattro. Her directionals stopped working and she's had to resort to manually moving the switch arm (the hazards work fine, though). Someone on the internet...
i think her problem is the hazard light switch this is how they go when they go wrong the indicators stop working ,their is no magic relay or seting dash lights --- not on such an old car ,the hazards work but no indicators ,they all use the same flasher unit but its all wired through teh hazard light switch ,anyway shes a female and they never use indicators anyway ,only hazards for triple parking outside the hairdresser
Dec 30, 2010 | 1999 Audi A6
I have a Remcon - R115 relay - - I have been told that they are no longer made - - must go to the R115S or the R120S. True? Options?
Yes, you need to go with the 115S (the 120S is the closet light - 2 wire - product.
Options GE RR7 relays, but they have no integral transformer
(also you could ebay for an old remcon device ( the one that the amprobes replaced :) )
Hope thi shelps
Aug 05, 2010 | Amprobe R-115S Remcon Relay Switch
MY WIPER ARE NOT WORKING I WAS TOLD THAT THE RELAY NEED TO BE REPLACED IS THAT TRUE
it could be. if you dont know electrical it might be a good idea to have a friend see if power is getting to the wiper motor or if power is going to the fuse. the relay should only be about $7 to $15
Feb 09, 2010 | 2005 Nissan Maxima
I just changed the radiator of my 2001 Maxima and the fan stopped working. It was working fine before I changed it. We checked the fuse, thermostat, wires and they all good. the mechanic told me that the...
The ECU drives a relay which in turn drives the fan. Trace the fan wiring back to the relay and check the plug connection. Does the fan turn freely by hand? If not, replace it. The fan needs a solid ground connection as well as power from the relay.
Aug 04, 2009 | 1988 Nissan Maxima
94 jeep cherokee: check engine light code 35
No its not true,the cooling fan comes on when the coolant temp reaches a certain point it closes the switch in the temp sensor wich in turn closes the relay and powers the cooling fan,the reason it comes on with the A/C is that it's wired to bypass the temp sensor and associated relay because the A/C compressor forces the motor to work harder and the coolant temp to rise significantly faster,the relay needs to be replaced or you will overheat the motor and possibly cause serious damage.
May 30, 2009 | 1994 Jeep Cherokee
Daytime running lights not working
a diode is just more than a buck at radio shak. but its probly dtrl relay under the hood at fuse box-distro box.
Jan 24, 2009 | 2005 GMC Yukon Xl Denali
'03 jetta tdi glow plug / DRL relay?
how many glow plugs are there and where are their locations
Dec 09, 2008 | 2003 Volkswagen Jetta TDI
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
Top Westwind Dryers Experts
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
