Question about Roland Vs-2000CD Digital Studio Workstation System
I have a Roland Versacamm and as it's printing an image that is supposed to be a rectangle shape 40"x60"...as it prints out the image is not straight it actually looks wavey like a flag? The printer was OK for 4 our of 10...then an error of cartridges not connected came up and the heads were manually pushed to the return position with the power still on...any ideas of what I can do?
  • Wesley Gardner
    Wesley Gardner May 11, 2010
    sounds like you need the printer to be aligned again what printer are you using? so we can narrow the possiblities down more.
    Problem Solver:
  • 9 Answers
This sounds like a scan motor error. clean encoding strip and test. If still wavy remove scan sensor the one that reads the encoder strip, clean with alcohol, replace and test. if still bad replace encoder strip and the eye that reads it.
Posted on Jun 26, 2011
Hi have had a similar problem with my roland SC500. It sound like you need to realign the heads. If you can find a service manual online for your printer it should tell you how to do this. It is very easy with the SC-500 not sure about the Versacamm but certainly sounds like out of alignment heads. Hope this helps!
Posted on Oct 01, 2009
I have a roland sp-540v, trying to print on banner material with black backing. Keeps on getting message to setup sheet while everything is loaded correct. The sensor is probably not picking up black.
Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Mar 23, 2016 | Roland VersaCAMM VP-540i
Distorted printingting
hello
try to clean the Encoder strip of your sp540, gently with alchool isoprophilic
i add a video explaining (the procedure and the result is the same for sp540) i hope this is helpfull. good luck
Feb 04, 2014 | Roland VersaCAMM SP-540V
Continuosly getting pinch roll error (invalid right position) on Roland versacamm sp-540v
if the problem is persists you have to replace the data cable connected to the head ( this cable goes foward and backward with the movement of the heads and sometimes it brokes ) i had the same problem and the solution is this.
Jan 31, 2014 | Roland VersaCAMM SP-540V
I need a driver for Roland VersaCAMM SP-540V for windows 7
IF I CAN REMEMBWE YOU CAN DOWNLOAD IT FROM THE ROLAND SITE
Nov 17, 2013 | Roland VersaCAMM SP-540V
I need drivers windowS 7 for Roland VersaCAMM SP-540V
hello
i add a video explaining how to install sp540v in win7
u need to install the Intercon-NetTool (that u can download from the Roland website) to allow the comunication with the plotter. its all well explained in the video. good luck
Feb 27, 2013 | Roland VersaCAMM SP-540V
My roland vp-540 will start printing and then when busy printing it will just stop, if you go into your versawork on computer it just says not connected? What could be the problem?
Just one Question?
Do you have your LAN Cable tied with your AC power Cable?
I have th same problem on two VP540 after seven years of trouble free working. A few months ago I was reorganizing my shop and I tied up both cables to avoid tangle cables with machine wheels every time I move It.
I think that the noise produced by AC Voltage Affect the VP540 ethernet port.
Aug 14, 2012 | Roland VersaCAMM VP-540i
Roland Versacamm sp540v is not printing yellow or magenta. What could be causing this? We were out of town and it wasn't used for a few weeks.
your print head dry out, cause is: no use! you should detach the tube between the pump and the caps, the one of magenta and yellow, insert a seringe in the tube (that comes from the cap) and suck some cc´s of ink, .then atatch the tube again and run one or two powerful cleanings, then run the test. A smart advise is: never turn off the machine in the main power, the machine when in stand by, does automatic a check and a cleaning process from time to time if needed.
Jun 24, 2012 | Roland VersaCAMM SP-540V
I want to know how involved is it to change the roland versacamm sp 300 print heads
Checkout the guide to replace the pump at:
http://www.decaldesigns.co.uk/img/Pump_replacement_procedure_sp_e.pdf
It also has the instructions to move Head Carriage
Sep 03, 2009 | Office Equipment & Supplies
Xerox 6250dp
I had this problem when I used a generic toner. I installed a xerox cyan toner, then printed many sheets of a large blue rectangle. After about 15 pages the blue started to spread into the shape, after 30 pages the blue was back. Printing a lot of blue was necessary to get the new toner thru the system.
May 29, 2008 | Xerox Phaser 6250 Laser Printer
Roland Vs-2000CD Digital Studio Workstation System Logo
796 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Greg Cann
Greg Cann
Vito Vacirca Jr.
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
