I bought xenon dvd 8020k. when i switch my tv to AV it was detected because i can see the xenon name on the screen. then i inserted my flash drive to the usb connection. then it says no disk so i remove my usb then when i inserted the cd there's no video and sounds in the tv. then i turn off and turn on the tv and dvd but there's no more xenon name appearing in AV screen. looks like dvd player is not detected
SOURCE: Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
Posted on Oct 11, 2006
dragon_sun25
  • 107 Answers
SOURCE: poor DVD drive audio Dell Inspiron
I also have an inspiron 1525 and I once had this issue (I'm running xp pro) but I found that you need to reinstall you audio driver, here is a link to the vista driver
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_1525&os=WLH&osl=en&catid=&impid=
Posted on Dec 12, 2008
SOURCE: DVD player is not able to detect WD 320 GB hard drive
Try reformating the drive with FAT32 file system (this is the default facotry mode).
Thanks,
Siva Kaza
Posted on Feb 26, 2009
  • 66 Answers
SOURCE: JLMS DVD-ROM XJ-HD166 cannot detect any CD
dear friend this is due to u are using a pirated cd .
or your computer lens is not able to read it .
so no need to worry if you have problem try other cd .
and if it fails please contact me
Posted on Mar 28, 2009
  • 8 Answers
SOURCE: Bought a maxell 8gb usb flash drive. When I try to...
By trying to use it I take that to mean you go to My Computer and select the drive you believe it to be.
Try going to My Computer with the flash drive unplugged and then plug it in while watching My Computer for a new drive letter to appear. That will be the one to use.
If you select the wrong one you will get the message you are experiencing.
Posted on May 21, 2010
LG HL-DT-ST DVD RAM GSA -H55N ATA dvd drive not detecting any dvds, while the cds are detected very well ????
built in 06 or 07 , it has reached the end of it's life expectancy , and need replaced
Oct 23, 2015 | LG Computers & Internet
I am trying to Connect my TV no: ALT2260M to Geepas DVD but not connected how can i start functioning?
Check its connecting wire [AV cord] first for any internal breakage to its conductor strands. Try with a new AV cable. After connecting the cable with TV and DVD player, switch the input to TV to AV. Power On the DVD player. If all connections are OK, you should see the brand emblem display of the DVD on TV screen. If not, make sure that there is some fault, either with TV or DVD player. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 04, 2014 | Televison & Video
When i plug my AV coil in my philips TV the screen goes dark
If the DVD player is playing and you have the Scart lead plugged in, check what the playback system is, Your TV is probably Composite Video and the DVD player may be set to RGB for example.
Mar 14, 2014 | Televison & Video
1. How do I watch the same movie on both screens on the Philips PET9422 37 9 in. Dual screen DVD players? 2. I bought a refurbished model but did not get a user's manual. How do I get one?
hi,
You can do the following to watch the same moving in both the screen.
1.Connect the AV out of both the unit together. with supplied av cord
2. If you want to watch the movie played on the first unit then put the DVD/AV IN switch of first monitor to DVD and the DVD/AV IN switch of second one to AV IN.Now you can watch the movie played on the first monitor on both monitors.
3. IF you want to watch movie played on the second unit then put DVD/AV IN switch of second monitor to DVD and the DVD/AV IN switch of the first monitor to AV IN. Now you can watch the movie played on the second monitor on both monitors.
I have the manual of the same . As it is large pdf file can't sent through fixya. If you can sent your email id through fixya will sent you the manual
ok
Jun 11, 2011 | Televison & Video
How do I find out how to put the tv on the right input on an older model phillips tv
Look on the back of the tv, the sockets that various leads are plugged into will have names next to them e.g. SCART-1 or AV - IN or RF IN. Make a note of which socket is used by your DVD player, VHS etc. with the TV on, switch on the device you want to use, let's say you want to watch a DVD. Some DVD players send a signal to the TV and the TV will automatically switch to the correct channel. If not you will have to select the channel manually. On the remote for the TV, look for a button marked "AV", "AV IN", "INPUT" or "SOURCE" press this button and you will either see a list of possible inputs, in which case, choose the correct one for your DVD player - e.g. SCART-1. If you don't see a list, the screen should flicker, go black, blue or straight to the DVD player. Keep pressing the button until you get to the desired input channel. To go back to normal tv, press TV on the remote or you may need to press the input button a few more times - depending on your tv.
Apr 05, 2011 | Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Wii powers up, Green light come on, then the TV screen goes black. I can insert and eject disc and do get a blue flash from the drive still only a black screen. Any ideas?
Test the tv you are using with another input, dvd player, etc to ensure that its not the tv unit causing the problem.
Secondly, you should try and get your hands on another AV cable for the Wii to test if the current AV cable you have is faulty. I hope this helps in solving your problem. Good luck.
Apr 20, 2010 | Nintendo Wii Console
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
How to change from tv to dvd mode
the difference between tv and av, is that av has no showers on the screen. if you change to av you will notice a blue screen, connect your yellow on vedio output and white/ red on audio out of tv
note- before connecting to a vedio touch a tip of your vedio cable some lines will show on your screen, if touch your audio tip harming noise will sound on your tv. if this two happens then you know that your cables are okey. hold your channel button on your tv, channel will start runing after all rf channels finish, tv will go to av.
Oct 13, 2008 | Sony DVP-NS50P DVD Player
No picture/sound on tv after connecting standard dvd player and inserting dvd
how many av inputs do you have on that tv? is it more than one? make sure you choose the right input. if that is not the problem then you are having a problem with av section in the tv I suggest that you take it to a repair man to get it fixed or you can use the RF cable to connect it to your tv. it is not the best but is saloution to the problem..good luck
May 13, 2007 | Daewoo DTQ-25S2FC 25" TV
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
