Question about Dishwashers
Wont let water in and have checked all pipes and filters
  • 4,323 Answers
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Mar 19, 2011
My siemens xlm 1400 wont fill with water so when it spins clothes are not cleaned.It won't drain properly either. It sees to only fill 10% of the water required. I have checked the pipes/hoses - a
I would take the back off and look for a small 5mm pipe leading upwards from the base of the drum and take it off and blow gently into it you should hear a click and one when you release the air if so then the place where you took the pipe from is blocked clean it out with a pipe cleaner or metal rod and replace the pipe as sometimes this pipe gets blocked with soap goo preventing the water sensor from doing its job eric
Jan 01, 2018 | Washing Machines
My hotpoint aqualtis aqxxd 169pm displays a blockage, we have cleared filter and checked pump is working, yet it still displays same message, and now when the power is on the drum wont turn.
Did you check the filter the pepellor sometimes can get something stuck in it. In one case i came across there was a hair go-go stuck in the pepellor.And also check the pipes at the back the cold water mains pipe going to the washing machine and the discharge pipe are not twisted or kinked
Aug 06, 2011 | Washing Machines
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Hotpoint aquarius ultima 1000, when wash cycle is comple the rinse cycle wont start and displays message check outlet pipe which i have done but it seems to be clear as i can syphon water from the machine...
It sounds as though the pump is not draining the water out.
If you have checked outlet pipe and it is clear, then you need to check the filter, if there is no filter at front of m/c, then remove the rear panel, and unfasten the large black hose that goes to bottom of drum, remove filter and clean, check pump at same time.
Watch out for water from the drum.
Refit filter and hose and test.
Plz rate my suggested solution, and feel free to leave a comment.
Thankyou.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Matsui dishwasher wont fill up with water
check your inlet filter at the tap source and behind the machine where the filler pipe enters. They changed some pipes in our street and fine sand filled our micro filters to the dishwasher.
Jan 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Hotpoint aquarius wf340
First remove the filter (if you can do this easily) - place a roasting pan under it to catch the water.
If you cannot get to any filter, remove the rear pipe from the waste pipe, and check it is not obstructed.
If it looks good enough, try a hot wash with 1 cup of soda crystals. This should clear any accumulation of grease in the pipes.
If still no good, you may have to open up the machine to clear any internal filter before the pump, and check pump vanes are still intact.
Nov 05, 2008 | Kenmore 13202 Top Load Washer
Front load washer
  1. Turn off machine and unplug it.
  2. Open filter it and clean it.
  3. Check if in pump turbine is clogged or jammed with foreign object. On some pumps you can test if turbine it rotates free using screwdriver or a finger.
  4. Check if the drain outlet pipe is clogged.
Unless pump motor is dead I'm 99% sure that either filter, pump and/or drain pipe are clogged.
Apr 20, 2008 | Washing Machines
Hotpoint aquarius 1000 deluxe
Try the "spin only" button to take the water out of your machine. If this does not work, take the pipe from the wall socket and lay it on the floor for the water to spill out. The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
Plug off the wall, & check your outlet filter first.
Nov 22, 2007 | Washing Machines
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
