1st istall networking driver for that particular printer . than when you will install the driver to computer . then it will detect printer automatically.
but you have to give a static ip to that printer ..
thanks to using fixya
don't forget to rating if you get the sollution...
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Glad that you got the solution but if you still confuse with the Setup process then you can take help of this blog to Setup HP Printer : https://printererrorstate.com/hp-printer-setup/
There is a problem with the sensor on the printer, try using an ink cartridge just for troubleshooting purposes, if everything fails. have it service or buy a new printer instead.
go on back of your tower theres an USB port there sometimes 2 just plug into either of them and your computer should auto detect the new device hope that helps
