Question about Generac Power Systems Generac 5522 14 Kw AirCooled Standby Generator
Brand new 14kw Generac 5872 with nexus controller....Generator starts up in MANUAL MODE for 5 seconds and shuts down saying "Low Voltage" alarm. No AC is present from the altenator for the 5 second period. All connections seem to be good under the hood...Any idea's?
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 17.5KW Generator dies
If this is one of the big "taco cart" portables you need to check that the vent on the gas cap is open when you're running the engine. In the center of the gage on the gas cap is a little knurled knob, turn it counter clockwise (lefty loosey), about a half turn or so and run the generator.
If that doesn't solve your problem add to it here, otherwise please give me a rating I'm trying to build a little credibility here and could use the help.
Carl
Posted on Dec 02, 2008
mydogisk
  • 50 Answers
SOURCE: Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Posted on Apr 13, 2009
  • 154 Answers
SOURCE: generac rv altenator wiring
white is neutral black is hot and green is ground
Posted on Jun 14, 2009
  • 17 Answers
SOURCE: Can't find manual for generac mega force generator
plain 30 wt is fine.
Posted on Jun 28, 2009
  • 10 Answers
SOURCE: I have a 17kw generac generator that will run
I have the 18KW model and was told that most alarms relate to a low battery. Make sure the battery charger in the Transfer Switch is properly feeding the battery or hook up a mobil battery charger to the battery and see if the alarm goes away. Good Luck.
Posted on Oct 12, 2009
My generac 15kw, brand new out off crate, runs on propane, says low voltage any idea of what would cause this!it fires for ten seconds and shuts down! thanks in advance! Ran first day no problem
low voltage can be from incorrect running rpms
as it is new out of the box I suggest that you get a service under warranty to sort out any problems
Jun 23, 2016 | Generac Electrical Supplies
Generac troubleshooting my generac 14kw generator engine runs why doesn*t it produce electricity
Assuming the generator circuit breaker is on, depending on the model it could be the voltage regulator or the slip ring brushes or both. If it's a portable it could be a capacitor problem.
Jul 02, 2014 | Electrical Supplies
Under voltage alarm /shutdown on generac 10 kw gen.
The brushes on Generac automatic units are most likely not lined up with the slip rings and will wear down and burn out very fast. There is no way of checking this during assenbly because they are hidden from view and the generator has to be dismantled to be able to replace them. It's an extremely poor design and Genrac should face a class action lawsuit for producing this piece of junk.
Sep 18, 2012 | Generac 6051 Guardian Series Air-Cooled...
Generac xl 4000 will not keep running after starting
try disconnecting the wire going to the low oil switch. if it runs then you need a new switch.
Sep 02, 2017 | Generac Electrical Supplies
I purchased a new Generac 20 KW air cooled standby generator. It shuts down under its excercise program and lists a low voltage fault code. I can start the unit in the manual mode and it starts and runs...
under warranty , you best have to wait the time as anything you do to fix it will void the warranty which will suit the service agent just fine
if you void the warranty he will get 2 hours travelling time plus the cost to repair time so don't touch it
Jan 05, 2018 | Generac Power Systems Generac 5522 14 Kw...
Generac generator remote start
si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
Dec 19, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Generac Power Systems Generac 5522 14 Kw AirCooled Standby Generator Logo
59 people viewed this question
Top Generac Power Systems Electrical Supplies Experts
John Trevino
richie46
Bill Boyd
Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
