SOURCE: Water leakage- V'spresso machine
the pool of water its probably the boiler that leak you can order a seal kit from saeco but itell you the bolt that hold the boiler you have to remove them to change the seal most of time they brake and you got to drill them out big job new seal kit for brew group cheers p.s descaling with vinegar no good descaling solution is the best solution melts calcium vinegar remove in flake and can block maybe thats why our valve leaking cheers
SOURCE: The coffee started coming out the brew spouts to
I had this same problem and called Jura Capresso. They had me straighten out a paper clip and stick it up each spout as far as I could and jiggle it around (after bringing the panel with the spouts down as far as possible) Then they said to **** the panel containing the spouts up and down several times and then press the rinse button. Repeat this process several times. That did the trick for me. They said sometimes the spouts get clogged and just need to be cleared.
SOURCE: how do I get my breville cafe roma espresso
Same thing happened to me and I had to push down on the water tank a little more firmly. It looked like it was seated okay but I guess it needed to be pushed down more to open the little spring-loaded opening at the bottom.
SOURCE: Saeco Magic Comfort plus: Despite descaling the
Hi
In the menu there is a program below the descaling program that says Reset descale. Enter this program and choose "yes", and make sure that you push the enter button to lock your answer. If you don't it will still be there.
Also go to your water hardness and move it to the #4. This will prevent you from having to replace the boiler sooner than needed. Descale when told to by the machine.
Testimonial: "Fast, correct and thorough. The cryptic Manual was less than clear but your instructions were excellent. thank you"
