SOURCE: Need remote Control Code for Pacific PTV 7017 TV Model
Hi! I've just bought a cheap universal (NOT 3 in 1/4 in 1) from Asda for £4.50,(model number TVRC1N by Masterplug) and I used the 'search' function as follows;
Power up tv
Press and hold 'tv' button (on bottom right on this control) until led blinks repeatedly
press 0000 ( a black button below the 8)
It should pick up the correct code almost immediately, and then you can test it by turning the tv on and off
Can now get AV1 and AV2
BINGO!
:~D
dude i got the same tv and this is the best answer : D
i have a navy blue sky remote controlling my tv and the code is 0584
Direct Code Entry
To program your universal remote to control your components
using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to
control
2. Locate the enclosed Code Lists. Find the list for the
component you wish to program. Find your component's
brand. You will see a listing of four-digit codes for each
brand.
3. Press and hold the component key (TV,
VCR•DVD, SAT•CBL) you wish to
program. The illuminated ON•OFF key
turns on and remains on. If you release
the component key at any time during the Direct Code
Entry procedure, the illuminated ON•OFF key blinks four
times, and the process is exited
4. While holding down the component key, consult the
Code Lists for the four-digit code that corresponds to your
component's brand and use the number keys (0-9) on the
keypad to enter it. While you are pressing the numbers, the
illuminated ON•OFF key turns off.
5. After the fourth number is entered, the illuminated ON•OFF
key turns on. At this time, release the component key. If the
illuminated ON•OFF key turns off, you have entered a valid
code and have followed the correct procedure for Direct
Code Entry.
If you enter a code number that is not in the Code Lists or
you do not follow all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks four times when the
component key is released. This is an indication that a
programming error has occurred. In that case, repeat the
Direct Code Entry process from step 3.
