Question about ASK Proxima C170 Multimedia Projector
How do you fix, Black/dark line down the edge of the projected image?
  • 442 Answers
I presume this when you are using the computer or component video inputs. try adjusting the PHASE setting
Posted on Mar 20, 2011
Screen has bright circle in center and dark around edges and corners
You may want to remove back cover and wipe/clean the three large black lens.
Also go to an unused video input and examine screen; Same problem?
Let me know what you find.
Steve
Feb 29, 2012 | Sony KP-61S65 61" Rear Projection...
Dark Screen and Blue Lines Arc Across Background
Hello!!
If the coolant is cloudy or has debris floating in it, the coolant will have to be changed and the lenses and crt face will need to be cleaned. Coolant can be ordered from any electronic distributer
Dec 28, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Hello I have several (7) blue lines in an arch pattern spanning across the entire screen. Mostly noticeable in dark to black scenes. Was wondering if anyone knows what causes this and if there is a way I...
The Blue CRT ( Picture Tube ) has a short. You may be able to do a temp fix by turning down the Blue CRT drive level ( Located behind the front speaker grille )untill the lines disappear. But its only a temp fix. The Blue CRT will most likely need replacement.
Nov 04, 2010 | Sony KP-51WS500 51" Rear Projection...
The brightness is very dark. Any nightime scene
Your CRT's getting old. Plus dust on lenses don't help much. You have to open front frill (below screen) and back of the TV. Clean up lenses using dry paper towels, do not wet.
In front of the TV after grill remove center cover and locate "black box" that have 6 potentiometers on it that looks like plastic adjustment screws for philips #2 screwdriver slots. 3 of them should read "Focus" These you don't touch. Another 3 reads "Screen". Put some still image on your screen (like paused DVD movie frame). Carefully add brightness in all 3 colors trying to avoid horizontal lines appearance. If lines show up, just turn it back a little. Try to keep color balance looking at the picture.
This procedure will brighten up image but further reduce CRT's life.
In case that you posted wrong model here and you have DLP Projection TV - just replace the lamp.
Mar 09, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Black/dark line down the edge of the projected image.
the light tunnel is collapsing. you can purchase the part from, or send the projector in to, an infocus authorized service center. try av solutions in ny. they're pretty good.
if you do chose to do it on your own, buy the part (315-0053-01). the tunnel is a rectangular mirrored tube located under the colorwheel between the lamp and the lens.
Nov 06, 2009 | ASK Proxima C170 Multimedia Projector
I have an Infocus LP350. The image it displays has lines running through it, which consists of the text displayed, but offset and a bit jumpy. There are also some dark black lines on the right. How can I...
if you reset the settings to factory default and the text is still like that, you have a colorwheel issue and probably a dmd chip problem. as for the dark lines, if they are more of a shadow on the edge, the colorwheel is collapsing. if they are thin and definite, you may have a main board or dmd chip problem.
Oct 23, 2009 | InFocus ScreenPlay 5700 Multimedia...
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Projection horizontal lines and flickering
This is the problem I had with a couple of my projectors, one of them I just replaced the bulb and the other needed whole new brains (controller board)
Feb 01, 2008 | Dell 3200MP Multimedia Projector
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Red lines
The top of my screen is pink and the color kind of bows down. The images are kind of distorted. Thanks for any help.
Sep 28, 2006 | Akai PT5598HD 55" Rear Projection...
ASK Proxima C170 Multimedia Projector Logo
60 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
Steven Wander
Steven Wander
Delage guy
Delage guy
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
