Question about Lenovo 3000 N200 0769 Intel Celeron 530 1.73GHz / 512MB DDR2 / 80GB HDD / DVD Player/ CD Burner / N... PC Desktop
Lenovo 3000 n200 0769AMU press power on switch green light on after about 1 sec screen still black no HD light fan running
  • Lenovo Master
  • 3,530 Answers
Welcome to Fixya
Try to drain the electrostatic charge of the motherboard that usually cause this issue. I wrote a tip on how to do the power drain. Try to plug in external monitor on the VGA port and see if you are getting display using external monitor. If you are getting display using external monitor then the problem would be the laptop LCD. If you are getting the same black screen using external monitor then the problem is already the motherboard.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Mar 23, 2011
Toshiba sattelite c660 restart
Try to access the BIOS screen, as check for the hardware helth and connection status.1) Black screen shows fault in RAM check he slot settings or other RAM.
2) If device shuts down itself in 2 seconds as you said, there might be a fault with the mother board or SMPS circuit which is not at related to any quarantined file by your AV.
Regards:
Himanshu
Aug 28, 2012 | Toshiba satellite c660
My lenovo 3000 N200 laptop shut down and will not start. I have unplugged the battery and power cable, I have cleaned the fan. No lights are appearing, nothing is happening when I press the power...
this could be a couple of things wrong.
1.i would try another power cable first.
2,can you hear if the fan is trying to run if not then you may need to take it to some one to have a look at it for you.
Oct 15, 2017 | Lenovo 3000 N200 Notebook
I have a lenovo 3000 n100 few days back i formated my hdd and installed windows xp over vista running before but now the is no display when i start my pc just a fan runs for a about 5 sec and then stop...
microsoft does do some not-so-nice things to its consumers ,bear this in mind,there are foreward compatability issues between some upgrades on some system,yours might be a backwards compatability issue
Sep 09, 2010 | Lenovo 3000 N100 Notebook
Hi. Since the computer is turning on we may try draining the electrostatic energy of the motherboard. Take out the batery and unplugged the power adapter from the wall socket. Press and hold the power button for 30 secs and put everything back in then turn ON the computer. If same problem appears then this cold be an LCD problem.
Mine is lenovo g430.i use windows 7.the system doesnt switch on.the indicaters and the fan comes on and stays.but nothindg is displayed on screen.
Try to perform power drain first as initial troubleshooting.
Procedures:
Take out the battery
Unplugged the power adapter
Put the battery back in
Plugged in the power adapter
Turn on the computer
If same issue will happened call our technical support department to have your laptop checked and scheduled for repair. This issue would be an LCD problem.
By the way. Is your unit still under warranty?
May 21, 2010 | Lenovo 3000 N200 Notebook
Power light comes on,fan starts then shuts down nothing hapens but power light stahys on.
try draining the battery first.in order to do this. batery should be taken out the laptop. power adapter is unplugged. press and hold the power button then counte 1 to 10 then release your finger after 10 secs. then press in again then count. do that for 3 times. plugged everything back in and monitor the status afterwards
Mar 06, 2010 | Lenovo 3000 N200 Notebook
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
Lenovo 3000 N200 laptop not starting up, power light on
Keep pressed the power button of your laptop for about 30 seconds, the machine will power down.
--The above step may not be required as already so many days passed by.
Then plug it into the power adapter.
Switch the laptop on.
Boot in "safe mode" (F8 during boot).
This will fix any driver or some operating system issue during previous failed boot process.
Once it boots completely, do a normal shutdown and reboot your laptop in standard mode (no more F8 this time).
Now your laptop will be ready to use.
Sep 30, 2009 | Lenovo 3000 N200 Notebook
Laptop fan spin for 2 second and display not show
You must veryfi the CPU and try without battery or try it without charger with a already charged battery! This must work!
Sep 13, 2009 | Lenovo 3000 N200 Notebook
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Open Questions:
lenovo 3000 N200 2048k ram passed Hay I am siva I am using the Lenovo 3000 N200( core-2) model laptop that system operation is vista but I am change to win- 7 professional 2 days have same hard drive corruption problem there showing all way this message A problem has been detected and windows his been shut down to prevent damage to your computer , If this is the first time you’ve seen this stop error screen, restart your computer .if this screen appears again, follow these steps Check for viruses on your computer .remove any newly installed hard drives or hard drive controllers, check your hard drive to make sure it is properly configured and terminated .run CHKDSK/F to check for hard drive corruption and then restart your computer . Technical information : Stop :0x0000007B (0x80D86B50,0XC000034,0X00000000, 0X00000000,) I am try to all when I restart the system there come windows error recovery launch startup repair ( recommended) then automatically go to the startup repair setup few mint check the repair then restart again go to the same setup start windows normally I try select the normally mode not go to the logon page again come same page how to solve the problem pl tell me I am try to all fun key nothing happened Phoemix TrustedCore(tm) NB Copyright 1985-2004 Pheonix Technologies Ltd. HDL10 BIOS Version 61ET33WW (V2.02) CPU = 1 Processors Detected, Cores per Processor = 2 Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz 1024M System RAM Passes 2048K Cache SRAM Passed System BIOS shadowed Video BIOS shadowed Press [F1] for SETUP, Press [F12] for boot device selection menu Pressing F1 changes the bottom line to "Entering SETUP...", but nothing else happens. Nothing happens if I press F12.
Jun 01, 2012 | Lenovo 3000 N200 0769 Intel Celeron 530...
Lenovo 3000 N200 0769 Intel Celeron 530 1.73GHz / 512MB DDR2 / 80GB HDD / DVD Player/ CD Burner / N... PC Desktop Logo
300 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
