Question about Samson C01U Consumer Microphone
Samson CO1U won't work - it's installed fine, the sonar LE cakewalk has installed aswell.. but for some reason it won't let me click on the Microphone to use as input. i am using windows 7 - will that have any effect?
  • 604 Answers
Hmm that is strange, are you seleting the mic as an input in the source for audio? the software works on win 7. have you tried other mics in the input on your sound card?
Posted on Mar 20, 2011
How download this program on mac Os
Download is different from Install. It does not look like you can purchase and download Cakewalk SONAR 7 Producer directly from Cakewalk. However, to install on a Mac, you either need BootCamp, or a virtual machine (VM) solution such as VMWare, Parallels, or VirtualBox, and a valid Windows 7 or 8 install.
System Requirements
Sep 03, 2013 | Cakewalk SONAR 7 Producer Edition -...
I plug in my usb for the samson studio gt. and no software comes up. but the box says it comes with it. what do I do?
I believe you're referring to the Cakewalk® Sonar LE music production software which should be in the box. If not any recording software will do. Click the link below and go to the page that says "STUDIO GT QUICK START" and follow the instructions.
http://s3.amazonaws.com/samsontech/related_docs/Studio%20GT_OM_ENG_V1.1.pdf
Jan 13, 2011 | Samson Studio GT Active Studio Monitors...
I bought this microphone w/ sonar LE. The mic is
You can probably solve your problem by plugging your mic into a powered usb hub, then plug the hub into your computer.
Jul 01, 2010 | Samson C01U Consumer Microphone
No live sound using Samson CO3U and Windows 7 x64
I don''t think you can solve this problem. The problem is that the computer has to digitize the incoming audio, then echo it out. This conversion takes time and is also governed by the real time clock servicing of the devices. You could try upping the priority of the conversion process, but I don't think you are going to be satisfied with the result either.
You would be happier to use a mic and external mixer where the audio is true real time rather than having the conversion latency time.
Jan 29, 2010 | Samson Audio C03upak Co3u Microphone with...
Cant get any sound from mic!!!!
Go into Play control on your computer. Click on options then properties. Look at your settings for playback and recording. Check play control and your source eg. microphone. To reach this double click on the speaker icon in your toolbar or you can find it under sounds and devices in your control panel.
May 23, 2009 | Samson C01U Consumer Microphone
Software doenst recognize mice
Try downloading ASIO4all and carefully following the directions.
Apr 23, 2009 | Samson C03U Professional Microphone
C01u PROBLEM PLS HELP ?!
That's the way it's supposed to work. It's a mono microphone, so there's only one signal to record.
Set up your recording software so that it only records the Left channel. It describes how to do this on the Samson FAQ page and in the Owner's Manual:
"In your digital audio workstation (DAW), create a mono audio track, and set it to the Left channel of the C01U (the Right channel should be ignored). Arm the track for recording, and adjust the input gain by using the software control in your computer's operating system"
Don't try to alter the pan so both sides are the same; that will just screw up the levels and noise.
Jan 08, 2009 | Samson C01U - USB Studio Condenser...
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
Imac-samson-gtrack mic compatability
From the Samson Audio website...
"Ideal for the traveling musician or the project studio, the G-Track ships with a desktop mic stand, swivel stand mount, USB cable and all the cables needed to connect any musical instrument with a standard 1/4" or RCA output. The G-Track ships with Cakewalk's Sonar LE and works brilliantly with Apple's GarageBand."
If it states that it works with GarageBand, I would say that it would work on a mac.
Nov 29, 2008 | Apple iMac 24" Desktop
Samson C01U Consumer Microphone Logo
455 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
