Question about Insignia NS-PDVD10 Portable DVD Player
Screen says NO DISC when there is a disc in and the door is closrd.
    Sergeant:
  • 194 Answers
Dvd cleaner would soulve your problem
Posted on Mar 19, 2011
  • sabari charan anand
    sabari charan anand Mar 20, 2011
    may be the lens has been damaged you have to replace it.
    If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
    P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
    * "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
    * "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
    * "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
    * "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
    Thank you for using FIXYA!
I have a disc stuck in the DVD player, it will not eject and the screen has the word open on the screen. What can I do to remove the disc from the player?
on the door there should be pin hole, stick a straightened out paper clip in the hole and push forward, the door will open, just be sure the power is unplugged
Dec 03, 2015 | Televison & Video
My ibm intellistation z pro: nothing appears on the screen no ibm sign at start up no nothing also if i try to open the disk drive it won't open which seems weird
maybe a disc stuck in the drive? if you pull down outter door of disc drive (unless you can see the front of the disc tray already) there is a tiny hole on front of disc tray, large enough to get a paper clip wire into, that will release the tray and pop it open
Mar 06, 2013 | Computers & Internet
My device cant open the disc tray please advise me on what to do
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
Feb 16, 2011 | Audio Players & Recorders
How do I format a DVD+RW disc?
Hello and Welcome to FixYa!
Here are the instructions for formatting DVD+RW discs.
  • Locate the CD-ROM drive door on your computer. The location of the drive depends on the computer you have. You will see a small rectangular button on the door.
  • Press the button and the drive door should slightly open. Lightly pull the door open and insert the blank DVD-RW disc into the drive. Close the drive door and wait for the computer to detect the disc, which will trigger an "Auto Play" screen to flash on the desktop's taskbar. The screen will prompt you to choose an action you'd like to perform for the disc.
  • Click "Burn Files to Disc: Using Windows." This link will redirect you to your Windows Explorer disc burning application. You will be prompted to enter a title for the disc.
  • Enter the title of your choice in the form and click "Next." The last screen will ask if you'd like to continue with the formatting; click "Yes" to continue. The "Elapsed Time" screen will appear indicating how long the process will take. When the process is complete, another screen will automatically appear indicating the formatting process is complete.
  • Click "OK" to continue. Your Windows Explorer panel will appear. In the upper-left corner of the panel, you will see a horizontal menu bar with different options for the disc. Now your disc is formatted and you can begin burning files to your disc.
    Have a nice Day,
    Concerned.
  • Jan 28, 2011 | Roxio Easy CD & DVD Burning for PC
    Disc door will not open
    The magnetic weight thats mounted on top of the dvd drive on the inside has came loose and jamming the door. Also it wont read the discs if this happens. I repair drive issues in PS3 and 360's with 99% success
    Jan 22, 2010 | Microsoft Xbox 360 Console
    Play station fell on the floor and the top is cracked. The screen turns blue when it comes on but will not read any discs nor open door.
    well it sounds like the sensor for reading disc is broke it will not read anymore disc the disc tray is also stuck will not open without repairs and the screen is turning blue because the video output inside the console(this transfers the picture onto the screen is busted if u have a warranty use it contact playstation by going to playstation.com hope this helps you.
    Dec 23, 2009 | Sony Playstation 3 (PS3) Console
    I can't get the Pavilion to play my disc of saved "documents"!???
    It can be. Sounds like your PC is having trouble reading that CD.
    You might try to copy the documents to your PC by draggin them to your desktop and then try opening them.
    Let me know how that works out.
    Thanks,
    Kaj
    Dec 16, 2008 | HP Pavilion Slimline S3123W Desktop PC -...
    No disc kicks disc out
    I have the problem of it refusing the disc if the door opens before I have filled the whole disc and finalized it. As long as I don't open the door till the disc is full and finalized, it works.
    Aug 30, 2008 | Samsung DVD-R130 DVD Recorder
    Durabrad DUR-1700 - No Disc
    turn on the power and open the dvd axcess door, inside where the dvd goes is a small little push down switch, push this down, it is in the upper right side. this will let you see if the laser is powering up,if you see no red light ,your laser is bad. hope this helps
    Aug 06, 2007 | Durabrand DUR-1700 Portable DVD Player
    Insignia NS-PDVD10 Portable DVD Player Logo
    Top Insignia Televison & Video Experts
    Jaime Hernandez
    Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
