Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I still use my Toshiba RD-XS35 to record TV?
    Guru:
  • 276 Answers
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Posted on Mar 19, 2011
    Problem Solver:
  • 9 Answers
There is no way to actually record HD signals in HD, other than a cable/satellite DVR that has a built in hard drive. You can record a signal from your HD receiver but it will only be 480i (standard definition) signal quality. You can thank the movie studios for that.
Posted on Sep 11, 2012
Upgraded older HD TV to a Sharp 70" smart TV & Home Theater Receiver (Yamaha RX-V575. Have AT&T U-verse HD Cable box. What is the connection sequence using HDMI cables. Searched Yamaha and AT&T sites and...
I dont know about your particular hd hookup , but I take the hdmi cable out of my dish reciever/dvr [digital video recorder] and run it straight to the hdmi input #2 in the back of my apex 40 in lcd-hd-tv
I think take the hdmi output from the at&t u-verse cable box and plug it into the hdmi input of your 70 in sharp smart tv
that will get the input signal from your cable box ,both video & audio, into your tv set.
on the back of your tv set
there should be audio outputs for home theater audio systems that would plug into the audio inputs of the home theater system.
prehaps i am wrong because you say that your yamaha is a home theater* reciever.* is the yahama more than a home theater audio system? What does it recieve?
Idea-- the salesman that you bought it from should be willing to help tell you how to hook it up.
also consider that there are many different ways to hook up vcr's and then dv recorders and dvd recorders and external 2 tera bite hard drives into my tv & dvr . I got that all hooked in & a rats nest of wires. so i can record in hd or sd,on vhs or dvd or dvr
point is that you cant hurt anything by plugging the wrong plug into the wrong jack, as long as the same type of plug goes into the same type of jack.
If its right,it works, if its wrong, it wont work until you plug it into the proper jack.
im sorry ,im 65 am not into knowing all the latest and greatest cutting edge tech ,but i am begining to catch up on my hobby, movie recording tech.
Oct 08, 2013 | AT&T UVerse
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
Sep 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Date says 4th march and I cannot change it
you will need to read the owners handbook for the specifics. if you cant find it, then the manual can be found below
http://www.tacp.toshiba.com/dvd/product.asp?model=rd-xs35
Mar 01, 2010 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
After couple of hours unit shut itself down please help
in the manual it says the DVR will shut down after 3 hours of inactivity . The DVR should put up a message to " press enter " to reset .
hope , it helps .
Jan 20, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba digital hd receiver/ hdd recorder
bypass the hdd and change input to see if tv works first
Aug 01, 2017 | Televison & Video
Will not power up but is still showing time
I changed my IR code by accident and now nothing works. I can not get back to the IR 1 code. Everytime I hit a button the DR3 appears but nothing works. How could I fix this.
Oct 01, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Hooking a vcr player to toshiba rd-xs35su
hi, connect it via a scart lead and switch to av channel.
Jan 13, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba dvd recorder #rd-xs35
The full manual can be downloaded from http://www.tacp.toshiba.com/dvr/product.asp?model=RD-XS35
The cable box hook-up is on page 22. There are two ways: 8bc47e0.jpg
Oct 25, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba tech support for this one. If it is not accepting the cleaner disk - you have to wonder if something is already intere or do you mean will not rune the disk? Inwhich case it is a drive failure and needs replacement[of drive if available] or whole machine. Contact Toshiba first though it may be a known issue.
Jul 05, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
274 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
