Question about Pride Jazzy 1113 Power Chair
My wheelchair shows full charge, 2 hours later, it is blinking and out of charge. This happens while I am at work and just setting at my desk. We had batteries tested and they are fine.
  • 692 Answers
Pride has a problem with a battery cable that will draw down the batteries like you say just sitting there and I'm not sure if it is with the Jazzy 1113. I would contact Pride @ 1-800-800-8586 ask for Jazzy Tech support and explain your problem. They should be able to tell you more specifically what the problem could be. I still think the batteries can be a cause of your problem but the Jazzy folks can help Hope this helps
Posted on Mar 20, 2011
Only two red lights show after some traveling.
It takes 5-6 full charges to brake a battery in. The first charge is 90%, then it increases. Also make sure that the caster and anti tilt wheels are free of dirt and any restrictions. Make sure that you don't exceed the weight capacity - most chairs are 300 lbs on a flat, hard surface.
Mar 14, 2013 | Health & Beauty
My Jazzy Select 14XL is having controller issues and I'm waiting for a new controller to come in the mail any day now. But I'm concerned about it fixing everything. There is an issue that I...
Sounds like your batteries have reached the end of their life cycle and are not holding a charge. If the 22NF batteries are more than 2 years old, have them load tested. They probably need to be replaced.
Apr 09, 2012 | Pride Health & Beauty
I had my wheel chair in storage for about an year, I have attempted to charge but when I disconnect the joy stick blinks yellow for low battery...How do I determine if both batteries are bad? If so do I...
Hi.Sounds like your batteries have sulphated plates, this happens when they sit for too long without being used. Your machine is a 24 volt system, so it needs both batteries to be working.You might be able to get a bit more life out of the batteries.
Try removing both batteries from the machine and connecting a light bulb across each battery and discharging them until they are flat.
Then using a 12 volt charger, ( not the charger for the machine, which is a 24 volt charger ), charge the 2 batteries in parallel. Sometimes it helps to charge them up the wrong way for a few hours, then discharge them again with the light bulbs. After this charge them again in parallel with the 12 volt charger, this time the correct polarity, a leave on charge for 12 hours.
You might have to repeat the charge, discharge cycle a few times.
The batteries will accept a charge after a bit of this, but they might not be as good as new batteries.
If you are unsure how to do this, get some help from someone who can do the work safely.
Good luck. Neil.
Jul 27, 2011 | Invacare Pronto M51 Power Wheelchair
JAZZY 1113 AFTER CHARGING 10 HOURS SHOWS ALL LIGHTS, THEN AFTER AN HOUR OF USE IT SHOWS 1 RED BLINKING. BATTERIES ARE ABOUT 1 YEAR, IT READS 26 VOLTS AT THE PINS ON CONTROLLER. ANY SUGGESTIONS?
Mary yep Even though the batteries are charging they are not holding the charge to provide enough power for the chair. Usually you have one battery that is weak and causing the problem but both batteries must be replaced. If Medicare paid for your chair then they will pay for 80% of the new batteries. You can contact the provider that sold you your chair and ask if they can replace your batteries. If not, you can contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have tech come out and repair the chair for you and they will bill Medicare for the cost of repair. Hope this helps
Feb 28, 2011 | Pride Jazzy 1113 ATS Indoor Power...
Purchased Norelco shaver 7810XL. Instructions state to charge for 4 hours prior to first use. Green lights began blinking, indicating full charge, after less than 2 hours. Do I continue charging after...
Simply follow the instructions and charge for a full 4 hours the first time. On subsequent charges, unplug when the light blinks after about 1 hour
Dec 26, 2010 | Norelco Health & Beauty
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
Charger shuts off before battery is fully charged
The batteries may have bad cells that will not allow a full charge. This can happen if the scooter has been stored for a while or if the charger has remained connected 24-7 for a long time.
Try replacing the batteries; cycle them 1-2 times to ensure they will take a full charge. (This means run the battery down into the red before you put it on the charger for 8-12 hours.)
Oct 10, 2010 | Pride Jazzy 1103 Ultra Standard Power...
The chair and its battery pack is 3 yrsold,not used,but when char
mcdevito75 here, If the battery--ies show charged they should be OK, still battery--ies that are 2--3 years old should be replaced. If your battery--ies show full charge, double check the connection for dirt, at the battery itself and at the motor.
Jun 22, 2010 | Everest & Jennings 20" Wheelchair With...
Battery doesn't charge
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced. This can happen if the power chair has not been charged in a while or has been stored. Having the chair on or off while charging will not affect the charging process, but you ususally want it to be OFF.
Mar 11, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Pride Jazzy 1113 Power Chair Logo
345 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
