Question about Xantrex Technology Xantrex Xpower 3000 Plus Inverter With Remote Switch - Inverters - Xantrex
I got an error of ER 05. What does that mean? Problem with the Xantrex Technology Xantrex Xpower 3000 Plus Inverter With Remote Switch. What is my solution, I shut off the 110 volt breakers in my main breaker panel in my RV, my Batteries are fully charged & load test perfect. Inverter comes up with ER 05 every time. Unit is 3 years old and has been used approx 100 hours.
  • Eugene Norris Mar 22, 2011
    We have had a stormy week, I will be trying this in a few days .
    Thank You
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
E05: Flashing Fault LED: Flashing Alarm: Beeping = Output on inverter is shortcircuit
- Disconnect your output terminals and see if you still have the code. This is telling you there is an external short.
- If you still have the error with the output terminals disconnected start looking for internal inverter shorts to the output connector. (Chaffed wire / hot wire signs / internal + lead ground)
- If you have Circuit Breakers / fuses on your output side open all the CB/s or remove all fuses then turn on the CB's / install fuses one at a time until you note the Er05 error. Then troubleshoot the shorted circuit with an Ohm Meter.
Thanks for choosing FixYa,
Kelly
Posted on Mar 19, 2011
  • gonzalez_mtl
    gonzalez_mtl Feb 18, 2013
    same her ..try to look inside for short..or burn marks but nothing ...bought the same unit ...but will like to fix this one thx
Xantrex power inverter 1750
The 14 AWG Positive wire should be connected to one side of a 30 A relay (typical fog lamp relay available at most automotive stores). The relay's other 30 A contact should be connected to the battery positive post via a 10 AWG (up to 6 ft/2 m)
Sep 07, 2008 | Xantrex Technology Xantrex Xpower 1750...
Serial#C11088451 no a/c output after switch is turned on from recepticle & battery charge % or output power watts display not working
Check inverter fuse, the fuse contacts and, check switch itself. I have seen numerous failed switches of the same configuration on other devices
Dec 30, 2011 | Xantrex Technology Statpower XPower...
My powersource400 have never last more than 4 hour and that is with a destop and a 75 watt bulb.
Assuming a car battery with a capacity of 70Ah at its nominal voltage of 12V, the total energy stored in it amounts to 12V * 70Ah = 940Wh.
Your Xantrex XPower 400 Inverter is designed to deliver continuous power of 320W at a specified efficiency of 90% (I doubt that, this degree may be achieved for ideal conditions of load / outside temperature / air humidity / current beer price, but not for the whole power range, but let it be 90% for the argument's sake).
Lets assume your desktop needs 150W of power (no high end CPU or graphics board involved), plus the 75W light bulb, plus 10% loss due to power conversion, gives a total of ~280W power need.
This is well inside specs, so no problem here.
However, your battery can deliver this power for 940Wh / 280W = 3.8h only until its completely depleted.
Your observation of four hours of time from full charge to depletion is thus quite exactly what you can expect, you have no reason for complaints unless you were promised a longer time under the conditions you give.
Oct 19, 2010 | Xantrex Technology Xantrex XPower Power...
14.1VDC going into inverter but no ACV coming out. Red fault light is on. Disconnected fan motor and checked with meter and shows open even on high ohm scale.Are Xantrex fan motors known to go bad?If the...
If you don't have enough current to run the inverter, even at 14.1 v, it will go into protection. Make sure the wiring is heavy enough to provide the current needed to run the inverter. There should be a label on the fan saying what vosges it needs to run. Try powering up the fan outside the inverter.
Nov 24, 2017 | Xantrex Technology Xantrex Xpower 1750...
Fues blown in xpower inverter 1750 plus
These fuse are often intend to protect voltage inversion. (reverse voltage)
So, if the eight fuse are blown, then maybe the voltage red and black wire were not connected to the correct polarity.
then again, even if these fuse are intend to be use as reverse protection, it may occure that transformer short out, transistor short out and many other short circuit inside the inverter as occure.
So replacing all eight fuse might not restore the unit function, they may even blow again.
Also, reversing polarity that cause the fuse to blow might have damage the transistor stage.
I am still, investigating few other problem with those unit.
I don't have all answer yet.
regards,
Hitheck
Dec 21, 2008 | Xantrex Technology Xantrex Xpower 1750...
Xantrex Technology Xantrex Xpower 3000 Plus Inverter With Remote Switch - Inverters - Xantrex Logo
476 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
EE Eddie
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
