Question about Microsoft Kinect Sensor for XBOX 360
Sensor tilt not moving to recognise child - Microsoft Kinect Sensor for XBOX 360
How to reset tilt sensor
Tilt sensors are usually a mercury liquid, or a ball and cage , and not really be reset, they can be adjusted by rotation or physically moving the unit itself.
Jun 12, 2014 | 2004 Yamaha YZF-R1
B1542 child lock
Can you check Enr and repost, model number is not recognised
Feb 22, 2013 | Neff Ovens
Graco highchair tray
Although the Graco high chair comes with a tray that you can tilt position wise, it shouldn't be tilting forwards.
Use the instruction manual and make sure that you have clipped it in properly.
If it's still tilting forwards then take it back to the place where you bought it to have it checked before you put a child in it, just in case it's faulty.
Good Luck
Aug 11, 2012 | Baby Gear
User manual auriol z29536-rx
It should be the same hardware as Ventus W155. Check:
Dec 31, 2011 | Measuring Tools & Sensors
2000 ford mustang thetf light flashing not allowing car to start. Checked all fuses. Alarm relay maybe?
There is a small ring around your ignition cylinder. There are 3 wires that run from it. It is some kind of sensor for the Theft or PATS key. If you use your tilt a lot, it seems to have a "undesirable" effect on the small wires...My Mustang Cobra did this one day. Had a great mechanic friend come over to the house...He just moved the column (tilted it about midway). Cranked right up!!! It still does it occasionaly, but all I have to do is move the tilt.
Sep 24, 2011 | 2000 Ford Mustang
To transport a loewe spheros 42 plasma unit with rotating stand does the tv unit detach from the stand? I understand that the plasma tv should be transported in an upright position only is this true?
Yes, it should be transported in upright position.
When we moved, our moving company arranged a crating company to crate our Spheros unit. They built a crate around the TV and secured it in an upright position along with the rotating stand. They then put a tilt sensor (you get the serial number of the tilt sensor) to make sure that the moving people don't tilt the crate. They also un-crate it at your destination. The only problem is that the TV is already quite heavy to begin with (~180 lbs), and with the crate, it becomes almost impossible for the movers move it in perfect upright position....though our movers really tried hard.
Sep 30, 2010 | Loewe Spheros 42HD 42 in. HD-Ready Plasma...
Child tilted 5 disc dvd player with discs in the
unplug the dvd player, now take the screws off the cover there may be 4 to 6 screws around it , from the back of player use both hands and lift the cover off gently .. you will gain access to the dvds DONOT SHAKE THEM OUT!!!!!! take them out gently one at a time... this should solve your problem..
Let me know if this worked
Good Luck...
Dec 23, 2009 | Yamaha DVD-C750 Multi-disc DVD Player
Jazzy 1113ATS will power up will allow tilt ajustments but will not move
It may be that the tilt sensor is not working right. Depending on the age of the chair, it will have either a mercury switch sensor that will disable drive when it sense a tilt of more than about 10 degrees, or older ones use two limit switches that are activated when the tilt reaches a certain setting. If one of the switches is stuck, it won't allow the chair to move but the tilt will still function properly. You'll need an experienced tech to test if you don't have the tools or training. Good luck.
Dec 08, 2009 | Pride Mobility Products Jazzy Select 14
Moved battery, no disconection, now fault 30 showing. Have i dislodged a wire? I have a PC3 connected.
Tilt switch sensor incorectly repositioned when reassambling tail end wiring "loom" Bike converted to track so wires just gaffa taped down.
Code 30 = Tilt Switch showing bike has fallen over..
May 17, 2009 | 2005 Yamaha YZF-R1
Microsoft Kinect Sensor for XBOX 360 Logo
144 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
