Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The washer does not stop filling with water at the chosen water level, small, medium, full etc
    President:
  • 2,468 Answers
Your water level pressure switch located inside the control panel is defective,there is wires and a plastic hose to this component,replace it and it will again fill correctly
Posted on Mar 19, 2011
Hello--My Maytag washer LAT8614AAE stopped while filling. It still spins, and stops spinning when top opened. I replaced water valve, so that wasn't the problem. Ideas? Thanks!
I would check the water level switch. It is activated when the water level is as per requested (low, medium, full). It might give the OK to the timer.
Jan 23, 2018 | Maytag Washing Machines
How much water Is required to fill it up?
The water level is chosen by the dial; light, medium or large.
Jun 23, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
The water level never stops, it just fills till it over flows
if on auto level select water level eg medium or low depending on amount of clothes this sometimes works dont use auto water level. If not check small pipe under touch board on top panel, make sure u unplug mains from plug pipe may be loose its small plastic goes to level sensor on right of board. If not level sensor faulty.
Feb 21, 2011 | Haier HLP21E Top Load Washer
Sometimes the machine just fills up with water, doesnt spin but continues to fill up and then leaks it out through the bottom, this happens especially when i try to wash with full load
The FRIGIDAIRE washing machine as in all washers have what is called a WATER LEVEL SWITH. This switch is on the top and this is where you select small,medium or large water levels. This water level switch has a clear hose from the top of swith to the side of the out tub. Please check the following:
1- check that the hose is hooked up on both sides and inspect it that it does not have any holes.
2- There could be a small sock or something foreign in between the inner and out drum therefore clogging up this hole.
3- Replace the water-level swith.
Nov 20, 2009 | Frigidaire FWS833A Top Load Washer
Washer doesn't fill with water. Only enough for a small load.
A - Two things could be your problem...
1) - sometimes the screens in the fill valve or inside the ends of the fill hose get clogged up...use a tooth brush to clean them out. Don't forget to shut off the water first before removing the hoses to check for this.
2) - The fill valve itself may not be opening fully = time for a new fill valve.
Dec 17, 2008 | Kenmore Washing Machines
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Maytag washer will not stop filling when wash cycle is first selected. Doesn't matter if I choose small, medium, or large load.
How do you get it stop filling? If it stops filling by just shutting the timer off you may have a bad pressure/water level switch, if you have too shut the water off too the machine at the wall then you have a bad inlet water valve.
Jul 30, 2008 | Maytag Washing Machines
When washer is in super wash cycle water will not stop causingthe tub to over fill running onto the floor.
It sounds like you are trying to use the largest water level setting. If this is correct you may have a pressure switch problem.
First turn the timer to spin and get all of the water out, that start a washer cycle with the water level set to the small or low setting and see if the washer fills to this level. if it stops at the low level great Now if it continues to fill and does stop you may need a pressure switch or the hose needs to be replaced that runs from the tub to the pressure switch.
Now set at the medium level and try again. does it stop or over fill?
If it over fills you probably need a pressure switch however before you purchase this, make sure the hose is in good condition one pin hole will cause your overfill condition.
Jul 09, 2008 | Washing Machines
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
42 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
