Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
My fisher and paykel dishwasher is making a loud noise now when it is actually dishwashing, i think it has something to do with the motor as the filter looks nice and clear. Do electric based dishwasher give off dangerous gases if they are broken, and it is it natural in the little basin after the wash is complete for it to have water in it.
Krazytech
  • 725 Answers
SOURCE: F4 error on fisher and
No increase in water
temperature during
wash cycle. --->
Faulty element.
Electronics controller
faulty.
Faulty temperature
sensor.
Check the heater thermistor and the wires to both...
Posted on Jun 16, 2008
reg501
  • 413 Answers
SOURCE: fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Posted on Jul 04, 2008
A-OK
  • 10 Answers
SOURCE: error 'u1' on fisher paykel dishwasher
Water Inlet Valve!
Posted on Nov 23, 2008
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
  • 3230 Answers
SOURCE: what is F4 error on
My Fisher and Paykel dishwasher has excessive motor noise. Help
it will most probably have corroded bearings in the motor, theres not much you can do other than replace the motor, ive never seen individual parts for sale for motors
Jan 28, 2017 | Fisher and Paykel Dishwashers
DS603 fisher paykel motor noise when starting up
The pump and motor for DD603 is the same device. It is a rotor lodged inside a cavity under the drain filter plate. I am assuming the dishdrawer is drained properly and at end of the wash there is no water sitting inside. You need to take the rotor device out from its cavity and check for damage. This video will help.http://www.youtube.com/watch?v=UXzuJvKIIgU
Mar 26, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
There is a loud noise while going through final stages of wash. Sounds like pump motor whineing.
Hello
When an appliance such as a dishwasher starts making a new noise, you need to isolate the cause of the noise so that you know whether or not it is damaging the machine. Several things can cause a noisy dishwasher.
Motor
Dishwashers are driven by an internal motor that gets quite noisy when defective. The problem occurs when a seal breaks down and allows water to access the bearings in the motor, removing the grease needed for proper lubrication and creating a loud motor noise when the dishwasher runs. The seal or bearings need to be replaced in this situation quickly or more extensive damage to the motor may occur.
Inlet Valve
If the inlet valve on your dishwasher is broken or breaking, you will hear a distinctive thumping or clattering noise whenever a load is run. A thumping noise doesn't always indicate this problem, however, depending on when you hear it. If you hear a noise like this when the water is filling up the dishwasher at the start of the cycle, the noise likely points to an inlet valve problem.
Squealing
A high-pitched squealing noise is an indication that something is wrong with the fan. Fan bearings that are worn out indicate that the fan apparatus needs to be replaced. If the noise you're hearing is in fact coming from the fan, it will only occur when the dishwasher is drying the dishes. Dishwashers use a fan to generate and distribute heat to dry the dishes quickly.
Minor Concerns
Sometimes even a minor concern can cause a great deal of noise. The thing to watch for is whether or not the noise repeats itself on multiple loads. A loud noise on a single load that doesn't repeat could be caused by things like a loose utensil or small implement rattling around loose in the dishwasher. Also inspect the bottom of your dishwasher. Hardened bits of old food can become rock hard under the heat in the dishwasher and cause noise when the unit runs.
Sep 11, 2011 | Fisher and Paykel 23 in. DD603H SS...
GThe motor is loud. The buttons beep alot. The sprayer is not spraying water.
You will need to replace your rotors if the motor is loud. Go to the link to watch a video that will show you how to fix most of your problems on your dishdrawer including replacing the rotors.
http://www.appliancerepairlesson.com/2011/02/25/fisher-and-paykel-dishwasher-dish-drawer-repair/
Good Luck
Mar 02, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer of dishwasher is making really loud"motorlike" sound. sounds like something is **** in the motor? Just started out of the blue.
The noise could be coming from the motor assembly. It is the grinding sound of rotor roughing against some hard food particle in the rotor cavity. Most likely a chicken bone or seed.
Take the rotor out and check. Refer to user manual for checking rotor cavity. It is possible the rotor may be damaged in which case you will need to replace it.
Sep 01, 2010 | Fisher and Paykel 23 in. DD603H SS...
I have a Fisher/Paykel dual drawer dishwasher and the top drawer now makes a loud grinding noise - appears to be coming from the front of the unit. Any thoughts? Any home-based solutions?
Remove dish rack, spray arm, remove filters, remove the rotor (under the spray arm) Check if the rotor itself is making any sound or not rotating freely when you turn the impeller on the top. Replace if needed, otherwise - carefully check for debris.
Nov 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer of dishwasher has a loud pump noise while running
Look for burrs on the botom impeller of the rotor. it requires no tools to check this. Take the wash arm and filter plate off, now rotate the motor rotor's base counter-clockwise and pull it out. Inspect the greay impeller closely for any nicks or burrs. If any are present, the impeller will make a LOT of noise. If it needs to be replaced, you can find them at fisher paykel parts, here is a link to the part you will need:
http://fisherpaykelparts.net/index.php?categoryid=113&productid=9
Nov 23, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
486 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
