Question about Battat Our Generation American Saddlebred Horse
Trying to figure out how to put back together a horse bridle for your horses that fit your 18" dolls. It's a brown bridle with white buckel things and one brown buckle thing. Do you have picture instuctions anywhere?
Tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Sep 23, 2009 | 1998 Ford Explorer
Tip
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 19, 2009 | 1987 Jeep Wrangler
Toy
replacement springs for some hobby horses are available at local hardware stores. Look for a select a spring assortment, or a store that can order from Servalite. They stock them in their catalog. Otherwise a handyman might be able to shorten the overstretched springs to raise the front legs.
Jun 15, 2013 | Tek Nek Toys Lucky Deluxe Spring Horse
Rocking horse replace band
I'm from Brazil, so a have a toda's kids rocking horse end a need those four rubber bands. How can I buy these replacement rubbers?
Feb 01, 2012 | Giddy Up Rocking Horse
We have the barbie tawny horse, my daughter got it for christmas, she opened it at the grandparents house, and the box and instructions were thrown out, i am trying to understand how it works, and how to...
The first thing to check is if you put in four AAA batteries. No, I'm not being condescending. When you open the battery lid on the underside of the horse, you will see slots for only two AAA batteries. This compartment actually comes out (pull the tab in the middle). Put in the four batteries, and put the compartment back in, ensuring that it's in the right way (the two contact pads need to be in the front). From there, you can push the horses head to have her walk (smooth surfaces only), pull the hind legs back or press her tail to winnie, etc.
If you still need the manual: http://service.mattel.com/us/product_detail.asp?id=N3286&Ntt=N3286&Pn=1&Brand=Barbie&Cat=Barbie+Accessories%2fFashions%2fPlaysets
Jan 15, 2011 | Mattel Toys
How to wire a towbar to a renault laguna ? what
If you have the Renault end, I've got the rest. I have the pinouts for 7 wire, 6 Wire and 4 Wire, One of them will fit the bill
White = Ground - 1
White = Ground - 1
Blue = Electric2_bing.gif Brakes - 2
White = Ground - GD
Red or Black (not both) = Battery2_bing.gif, aux power - A
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
A test light and a 12VDC power source can be handy for trouble shooting
Best regards
Aug 14, 2010 | 2007 Renault R18
Repair manual for double horse 9077 change bottom blade holder
How much charging time for double horse 9077 egle...using original charger
Jun 23, 2010 | SYMA Toys industrial 9077 Double Horse...
How do we get the bridle and the saddle on the horse.
your horse has to be fully grown. Pick up the sadlle bridle and sadle pad put them in your inventory go over to the horse click on each item and then click on your horse
May 21, 2010 | ValuSoft Let's Ride Friends Forever for PC...
Spring Horse
You can go to the Radio Flyer website and download the assembly instructions.
Jan 10, 2009 | Radio Flyer Liberty The Spring Horse By
Battat Our Generation American Saddlebred Horse Logo
171 people viewed this question
Top Battat Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Battat Toy Expert? Answer questions, earn points and help others
