Question about Troy-Bilt Pony Garden Tiller
The tiller was working fine for about an hour. I let it rest for 15 min, then briefly turned it on its right side work on left wheel. It started right up, but then stalled about a minute later and won't restart.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Laying your tiller of its right side can fill engine breather with oil and possibly entering your carburator causing engine to smoke and then quite. If this is so change or clean your spark plug. It this is not the case your crankshaft seal may be bad allowing oil to enter your ignition point and condenser cavity causing points to get wet.
Posted on Mar 27, 2011
Why doesn't right wheel work?
I would like to know the same thing! I have that exact issue
Feb 29, 2016 | Scag SFZ52-26BS Freedom Z Zero Turn Rider
Key will not turn in 2002 S430
Just some suggestions.
Clean the end of your key and get an earbud and metho/alchol and clean the keyhole sensor.
Change the battery in your key.
Check the charge level on the battery. Recharge.
Check alternator charging.
climatecontrol diagnostic menu
To enter mode press "REST" for more than 5 seconds. Use the left & right Auto buttons to scroll.
standing
value code description
15 1 Inside Temperature
11 2 Outside Temperature
11 3 Left Heater Core Temperature
10 4 Right Heater Core Temperature
10 5 Evaporator Temperature
11 6 Engine Coolant Temperature
3 7 Refrigerant Pressure: displayed as 1.xx bar where xx is in the display
10 8 Refrigerant Temperature
0 9 Not Used
1.2 10 Blower Control Voltage: 6.0V
11 Emission Sensor: 2.4V
12 Sun Sensor: 4.1V
0 20 Control Current for Auxiliary Fan: 3.2mA (Is this value too low?)
0 21 Engine RPM: 44 => 4,400rpm
0 22 Vehicle Speed
0 23 Terminal 58d: 32 or 32% of Full Battery Charge
12.0 24 Battery Voltage: 13.3V
8 40 Software Status: 164
5 41 Hardware Status: 85
216 42 Variant Code 1st numerical value
14 43 Variant Code 2nd numerical value
50 Not assigned
51 Not assigned
52 Not assignd
60 Roof OPE/CLO
61 Left side air outlet, knurled wheel potentiometer Volts
62 Vacuum actuator 46, feedback potentiometer Volts
63 Center outlet, knurled wheel potentiometer Volts
64 Vacuum actuator 47, feedback potentiometer Volts
65 Right side air outlet, knurled wheel potentiometer Volts
66 Vacuum actuator 48, feedback potentiometer Volts
Item 63 is the input signal from the thumbwheel controlfor the center vent, and 64 is the feedback signal to the controller giving it the position of the vent flap. As you move the thumbwheel these values should continously vary from a minimum of roughly .7 to 4.5.
Apr 03, 2017 | 2002 Mercedes-Benz S-Class
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Aug 29, 2010 | Troy-Bilt Garden
How do I change the belts on a troy bilt tiller
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
May 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Changing the drive belt
pull the bracket
Apr 12, 2009 | Troy-Bilt Pony Garden Tiller
2004 GMC Yukon Denali
My wife had same problem in 2005 yukon. Turn both temperture controls on dash all the way as warm as they will go, Wait about 1 or 2 mins and turn back to coolest setting. Cleared our problem right up. Do this with car running and air on.
Oct 02, 2008 | 2005 GMC Yukon Denali
Driver front side wheel
Sounds like you have a failing wheel bearing. Once you start hearing it, does it get louder or more high pitched the faster you go? Do you hear it get quieter when you turn left at speed, or louder when you go right at speed? If any of those are a yes, I'd have the wheel bearing inspected and replaced if necessary.
Aug 20, 2008 | 2006 Chevrolet Trailblazer
Service required
the problem never happens when it's cool or cold
my problem always happens when i turn the unit on, not while already riding/driving out of the blue
i believe the problem might be from the unit getting hot from being in a car, or on a motorcycle, or in a jacket in the hot sun then powering it up while still very hot, some kind of overheat circuit
find a way to cool it off, ride a short distance with it turned off then turn it on or...
also take the 8500 in you right hand and tap it in you left hand 3-5 times, it should start up and be fine. this doesn't have anything to do with temperature but i've had luck with it
good luck
May 19, 2008 | Passport 8500 Radar Detector
Instructions for Sunbeam clock model # 882-495
Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/auto.off is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
Mar 29, 2008 | Office Equipment & Supplies
Troy-Bilt Pony Garden Tiller Logo
185 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
