Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side ( later model)
Fridge is at 60 Degrees f, but freezer ok and fan running
    Champion:
  • 210 Answers
Could be defrost problem. check the back of freezer panel closely for frosty ice build-up.
Posted on Aug 04, 2008
Ge profile pss25sgna - freezer 60 degrees and fridge 58
the compressor is not running,you need to buy a new ptc overload/relay and replace the defective one on the compressor,it unplugs off the side of the compressor,its what starts and runs the compressor
Mar 16, 2013 | GE Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
My GE Bottom Freezer Refrigerator Model:PFS22SBSSS The Refrigerator is not cooling, however the Freezer is mantianing proper temprature at 0 degrees. The temp on the fridge is reading 60 degrees on the...
Your problem is almost surely caused by the failure of the fan that should circulate cooled air from the freezer section to the refrigerator. If you check for vents, normally in the rear of the fridge, and hold your fingers in front of them while you hear the compressor running, you should easily feel cold air coming from them if the fan is running.
To determine whether you want to have it serviced or replace the fan yourself, try entering your model number on the Sears PartsDirect website to see if your unit is one of thousands of non-Sears appliances in their library. If they do, then you will find an illustrated parts drawing with part numbers.
Sears PartsDirect
Sep 06, 2010 | GE PFS22SBSSS Stainless Steel French Door...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
May 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan noise in freezer of my GE side-by-side refridgerator
You don't have to worry about the ice and frost, Your heater does that for you Your heater comes on and defrost every day. You just need to tighten the screws and clean up the vent where the noise is coming from but I wouldn't worry about it. The temperature on your fridge and freezer is running optimal, You know the saying, if it ain't broke, don't try to fix it....just tap the vent covers every few days.
Dec 06, 2008 | Refrigerators
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
70 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
