Question about Car Audio & Video
I have a 2003 Toyota Sequoia, and the movie player is a Toyota DVD audio / video player 57005. The problem is it simply doesn't play anything any more. It's been broken for a year or more, now my wife bought a unit that fits, BUT...the wiring in back doesn't match. The original, which we have out, has one big plug in back with aprox 14 pins in it. the new unit has two sets of red/ yellow/ white leads, and then one black lead. What to do? Maybe would have een easier to fix the old one somehow?
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
  • 2692 Answers
SOURCE: unplugged wires on the motherboard
Fix Ya?
Posted on Apr 04, 2009
  • 31 Answers
SOURCE: How to wire a tach on 05 heritage softail
Locate & route Black lead to ground / 2004-later softail: On the frame strap under the seat directly in front of the battery.
Locate & route the pink lead to Signal / For 2004 & later FXST/C/I The #3 cavity in the connector {39b} on the back of the speedometer. The socket terminal on the signal (pk) lead fits the #3 cavity.
Locate & route the Orange and white lead to power / Ummm.. it's saying for 2004 and later to adapt to the fuse block For earlier [ For 1996 to 2003 softail: locate the power lead (o/w) in the tail lamp pin connector {7a} under the seat behind the right rear corner of he battery.] "here you are looking to run it to a fused line, not directly to power/battery" I hope this helped.
Posted on Sep 19, 2009
  • 11 Answers
SOURCE: Fitting a Kenwood car stereo
The vehicle chassis ground or negative is opposite to the stereo. The aerial is vehicle chassis ground (earth), when touched to stereo results in direct short. If the Hilux is positive ( + ) chassis (earth) and the stereo is negaitive ( - ) ground, there is the short. If this is the problem, either replace with a compatable stereo or compatable vehicle.
Posted on Nov 07, 2009
  • 909 Answers
SOURCE: no sound with wii
if you do not have the red/white socket on the rear of the tv(audio in) then you could use a scart adapter. it will have the 3 connections on the rear of a scart head. most flat panel tvs have the 3 connections on the side or the front under a flap.
Posted on Feb 21, 2010
Testimonial: "very quick and thoughtful"
2003 Chrysler Town & Country DVD Player doesn't output picture to screen, audio on right side only.
The cost to repair it will cost you more then to just buy a used one from a auto wrecker.
Oct 19, 2012 | 2003 Chrysler Town & Country
How to remove personal code from dvd system
I started tyring combinations figuring if I locked it out it was going to the dealership anyway. 0000 worked for me. It may work for you too. Would have like to have thought that Toyota would have stated what the default was in the manual.
Oct 01, 2012 | 2004 Toyota Sequoia
I have a factory installed dcs player in my 2005 Toyota Sequoia. The dvd player will play dvds (the only way you know it is on is you can hear the video) but the screen is black. What is wrong?
The monitor can be reset by diconnecting the battery or by the reset button on the radio. If that does not work then the DVD player needs repaired or replaced.
Apr 14, 2011 | Car Audio & Video
Converting Movies To Play On My Home Dvd Player
Convert video to .avi or DVD (Audio TS- Video VS) format.
Many common dvd players can play .avi files
(.avi files are very compact).
All dvd players play TS/VS format.
AVS4U is a reasonably priced (approx $50)downloadable suite of programs that can perform all the conversion tasks you need for audio & video.
Jul 11, 2009 | Televison & Video
Mine wont play anything a DVD it recorded it wont let me finalize
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jul 07, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Audio/video problem with dur 1700
I'm really confused abt ur problem.
Can u please explain a little bit more
Nov 18, 2008 | Durabrand DUR-1700 Portable DVD Player
Car Audio & Video Logo
108 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
