Question about KitchenAid Kitchen Ranges
Burner wont light on my kitchenaid stove - KitchenAid Kitchen Ranges
    Sergeant:
  • 194 Answers
TRY CLEANING THE BURNER OR CHECK THE BATTERY
Posted on Mar 19, 2011
aborcass
  • 2651 Answers
SOURCE: KItchenaid supera gas stove
thers is a thermal cut-offs under the main control area little black thermostat one controls display andother turns fan on/off
Posted on Feb 24, 2008
craigjamesbt
  • 65 Answers
SOURCE: stove burners won't ignoite
just to be clear I am assuming that you can in fact see a spark traveling from the ignitor to the metal surface over where the gas should be expelled... that being the case you must remove the the gas burner from the stove and check for damage or sign of deterioration ie: cracks, rust holes, missing sections etc. more than likely if there is no damage after 7 years of use the problem will be in the form of carbon and rust deposits inside the burner pieces or associated piping (pipe that are in the burning side of the system don't tear into the gas side) *NOTE THIS WILL NOT KEEP GAS FROM COMING OUT BUT MAY PREVENT IT FROM EXITING IN THE PROPER PLACES DESIGNED FOR LIGHTING* you can clean these carbon deposits by tipping the open end face down and tapping the burner pieces with a block of wood or similar device. These deposits should fall out as a heavy black or reddish brown dust you can also try vacuuming it and running an appropriately size drill bit through each of the burner holes to clean them as well or you can probably just purchase a new one by ordering it from the place you bought the stove
Posted on Apr 26, 2009
SOURCE: kitchenaid gas stove left back burner won't light. hear clicking
I have a Kitchen Aid gas stove. All the burners will not light. No clicking, NOTHING. Is there a lighting switch or something that needs to be replaced ?? Or do I replace all 4 lighters ??
Posted on Jun 26, 2009
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
iwillfixforu
  • 619 Answers
SOURCE: My KitchenAid KGRA806PSS Stove's Burners won't
Bad power source. Not getting 240 volts to oven. reset breaker by turng off the back on for the stove. 240 volt double breaker. If this doesn't work problem will be where stove plugs in.
Posted on Feb 02, 2010
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
My KitchenAid KGRA806PSS Stove's Burners won't light. And the stove gets up to 200 degrees but no further.
Feb 01, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
Stove top difficult to light
your gas jets are dirty.. clean them with a toothbrush (after everything is cooled down).. you can use the selfclean to clean the iron pieces that cover the burners..
be careful with kitchen aid self cleaning.. there is a known issue with the thermal fuses blowing quite easily on most self cleaning cycles..
good luck
tpug
Feb 21, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Feb 08, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
46 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
