Question about Dryers
LG DLG2524, cooling light is on constantly, dryer has no heat but other wise works ok?
    President:
  • 3,074 Answers
Http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Posted on Mar 19, 2011
I have and lg gas dryer modeldlg7188rm cooling light is on constant wouldnt heat atall. replaced gas valve now it will fire up but after a few seconds shuts down. Cooling light still on on any cycle is it...
Most dryers if and when they have issues can be traced to the circuit board main IC software or IC flaws. Replacing the board with a new or rebuild board usually fixes all
Oct 31, 2013 | LG Dryers
The dryer is taking a lot longer to dry now than before. I'm sure it's not lint, insufficient gas supply or the vent needing cleaned. The cooling light is staying on solid and the drying light...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 06, 2011 | LG DLG2524 Gas Dryer
Lg Gas Dyer, "cooling" light is on and there is no heat
Most likely the igniter needs replacing tho it also could be thermistor or lack of gas flow or a few others.
Feb 15, 2018 | LG DLG2524 Gas Dryer
Dlg2524 gas dryer runs but won't heat and the cooling light stays on it also seems like the heating element is not igniting
Check the vent going outside , many time this is the number 1 problem the vent it plug up or the pipe is kink
Apr 15, 2009 | LG Dryers
Lg gas dryer not igniting/no heat
If your dryer is any of these modes here listed below. I'm sending you a repair manual to help you. I'm not sure of your model number but these dryers are basically the same problems, Igniters, temperature switch, solenoid coils or door switch interruptions I would focus on the solenoid exhaust blockage, high limit , electronic heat sensor first, Thanks, Sea Breeze click below
http://136.166.4.200/contents/Laundry/DLG2524/DLG2524_Service_Manual.pdf
Apr 10, 2009 | LG Dryers
Whirlpool ultimate ii electric dryer stopped heating
change out the heat element, you can get the part at Sear
Nov 27, 2008 | LG DLG2524 Gas Dryer
Cooling light on?
The cooling light is always on, it flashes when it is in that part of the cycle, sounds like he put it in to a test mode. Was it a thermistor that he changed?
No heat, sounds to me like a thermostat might be blown. Call the guy back, if you haven't already.
Sgt 48
Apr 05, 2008 | LG DLE5977 Electric Dryer
LG Gas Stacking Dryer
Check the vent and make sure it is not plugged with lint. Make sure the vent hose is clear. The light is telling you something blocking the airflow. You might not be able to see it easily.
Jun 18, 2007 | LG DLG2524 Gas Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
