Question about Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by
After flushing the toliet makes a humming sound.
    Problem Solver:
  • 13 Answers
You have to turn the lever or knob in the reverse direction to plug the hole properly, the noise would go away.
Posted on Mar 19, 2011
Running toliet
Then you either have to lower the water height so that it doesn't overflow the overflow tube, or you have to replace a seal on the ballcock or replace the ballcock with a modern style.
Nov 28, 2013 | Home
I have a Jacuzzi low flow toliet. Sometimes the water won't shut off after it is flushed
A frequent cause of this is a defective flapper. If the flapper does not seat properly after a flush, the refill water will flow continuously
Feb 19, 2013 | Home
I have a single flush toliet and I am getting a poor flush.Toliet is 2 years old and was mad in 2006
Adjust the float height to allow mor water into the tank before it shuts the valve
Jan 22, 2011 | Kohler Home
I have a thetford Model 31687 rv toliet. I get a slow leak on the floor, and the back of the toliet seems to be wet around the flush valve. Is there a rebuilt kit for this toliet?
They don't have rebuilt parts kits that I am awareof, but you can get replacement parts for them at most any RV service center. They are pretty easy to repair yourself.
Tool Belt Diva
Sep 24, 2010 | Thetford Porta Potti
Toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
Jul 08, 2010 | Toto Drake ADA Compliant Toilet with...
Toilet Question
Yes, it will run up your bill! Sounds like the float is hanging up. Take tank lid off and flush, watch the float and if your tank fills quickly but does not stop, bend the float arm to angle the float down further, this should allow your water to stop coming in much quicker. The other possibility could be if the plug at the bottom does not seal correctly after flushing, if so, the water will leak until the plug sits down all the way.
Apr 11, 2009 | Kohler K-4709-96 C3-200 elongated toilet...
Tank will not refill after you flush
okay depending on the type of toilet ball **** (i know its a funny word, but it's really what its called.) you have one the most standard type is the long wire with the big ball on the end. you need to adjust this ball **** so it goes lower test it out, flush your toilett and wait till the water drains then when its supposed to come back up push down on the ball **** and youll see the water will start to fill, so then adjust the little screw on the fill valve (the other side of the floater where its attached)
you may need to shut off your water supply and drain your tank depending on how skilled you are,
pretty simple work, if you have questions feel free to ask.
Nov 16, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
370 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
