Question about Homedics Glass Digital Scale - Advanced Computerized 400 Pound Capacity
Scale adds 5.2lbs everytime you turn it on, is there a way to wipe out the settings or reset this scale?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 141 Answers
Set in default mode..............
Posted on Mar 19, 2011
My pocket digital scale says full?
some one help ..when i turn on scales it says full what does that mean how do i fix
Nov 21, 2013 | Health & Beauty
How to reset my Conair WW37BFX Weight Watchers scale
Whenever I try to add weight to my user it says error. Any help?
Aug 26, 2013 | Health & Beauty
How do I change the age on my healthometer scale, model BFM676KD01
Press Left "Select" key; Press Right "Scroll" Key to select USER (Digital Display flashes to show USER #); Press and HOLD "Select" Key until "Height" flashes; Press "Scroll" to advance Height '; Press "Select" to move to next input. When "Age" flashes, press "Scroll" to your age, and you're done!
Nov 17, 2011 | Health & Beauty
Its nan oxo pull out display food scale and the screen reads F when turning it on
My OXO scale has a removable weighing platform. I removed it and wiped off the top of the scale base. When I put the platform back in place and turned the scale on, the display showed the normal numbers and icons. The F was gone.
Apr 07, 2011 | Microwave Ovens
My scale adds anywhere from 5 lbs to 35 lbs to my family's weight. I just had my daughter weighed yesterday and this scale added 5 lbs and when my husband or I get on it, it adds anywhere from 30 to 35 lbs...
there should be a dial on the sides to zero it out. if it doesnt, then it has something to do on the actual scale. does it have a menu or settings option? you should be able to zero it out.
Dec 10, 2010 | Homedics Glass Digital Scale - Advanced...
HOW TO DE SCALE THE Philips AVENT Digital Bottle
Mix one sachet of citric acid* (10g) with 200ml/7oz of water. Pour solution into the
empty warmer. DO NOT place a bottle, jar or cup into the warmer when de-scaling.
Close the lid of the warmer and programme the warmer to run with 310ml/11oz of
milk from frozen. After the warming cycle has ended, leave the solution to cool for
30 minutes before emptying the warmer and rinsing with tap water. Wipe the inside
and outside of the warmer with a damp cloth only.
OR:
Pour 100ml/3.5oz of vinegar mixed with 200ml/7oz of cold water into the warmer.
Allow liquid to stand in the unit until any limescale has dissolved. DO NOT place a
bottle, jar or cup into the warmer when de-scaling. DO NOT start the warming cycle.
Empty the unit and rinse thoroughly. Wipe the inside and outside of the warmer with
a damp cloth only.
Jan 30, 2010 | Avent Philips iQ Bottle Warmer without...
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
Tried to reboot to factory settings
You have to make sure when going through the setup (if given the option) to install a clean copy and not install windows to another directory. If you have access to a floppy disk drive an easier way would to be to create a dos boot disk and reformat your c:drive. Make sure you do not have any data on this laptop you want to save. If that does not work you can try to get a DOS program called FDISK. It will wipe out the hard drive partitions so that you can reload your laptop from scratch. Let us know how it goes.
Apr 27, 2009 | IBM ThinkPad T23 2647 Notebook
Humidifier does not reset
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
20 minutes, cleaning all interior surfaces with a soft
brush. Dampen a cloth with undiluted white vinegar
and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the
white vinegar solution before beginning to disinfect
the tank.
4. Wipe the heating element clean with a soft cloth after
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
http://www.holmesproducts.com/Manuals/Holmes/HM5250-UC_English.pdf
Good Luck.
Apr 07, 2008 | Holmes Products HM5250-UC Humidifier
Homedics Glass Digital Scale - Advanced Computerized 400 Pound Capacity Logo
235 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
