Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How to install cables - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
    President:
  • 3,197 Answers
This can get very dangerous and I do not recommend a DIYer doing it.
Posted on Mar 21, 2011
How to access/replace the vent selector(defroster) ?
buy one
and install it.
it has clamps remove them or unsnap them and .....
access? its in the dash.
the FSM covers all HVAC work , you can get that and read it
or hope that ALLDATA.com covers R&R for the cables.
but will cover access. (huge job on some cars)
working on the dash with out and FSM invites more broken parts.
plastics.
hidden screws and such , and how to get to them are covered in the book.
here is the control panel, pasted
Removal & Installation
  1. Remove the upper console panel.
  2. Remove the instrument cluster finish panel
  3. Release the 2 fitting claws and pull out the heater control assembly.
  4. Using a screwdriver, open the claw of the cable clamp and disconnect the defroster damper control cable. NOTE Be careful not to bend the cable wire. If the cable wire bends, the heater control assembly operationally becomes worse.
  5. Using a screwdriver, open the claw of the cable clamp and disconnect the air mix damper control cable.
  6. Disconnect the connector, remove the heater control assembly. 42050_coro_g0008.gif Removal and installation of the control panel
To install:
  1. Install the inner cable end of the air mix damper control cable to the heater control lever.
  2. Install the outer cable of the air mix damper control cable to the cable clamp. NOTE Be careful not to bend the cable wire. If the cable wire bends, the heater control assembly operationally becomes worse.
  3. Operating the heater control knob and check that it properly stops at both ends of MAX. COOL and MAX. HOT and no recoil is identified.
  4. Check that the outer cable should not be disengaged (moved) from the heater control assembly when the cable is pulled.
  5. Install the inner cable end of the defroster damper control cable to the heater control lever.
  6. Install the outer cable of the defroster damper control cable to the cable clamp.
  7. Operating the heater control knob and check that it properly stops at both ends of FACE and DEF and no recoil is identified.
  8. Check that the outer cable should not be disengaged (moved) from the heater control assembly when the cable is pulled.
  9. Connect the connector, install the heater control assembly.
  10. Install the instrument cluster finish panel
  11. Install the upper console panel.
Dec 13, 2013 | 2005 Toyota Corolla
Diagram for parking brake cables
  1. For the 1500HD, relieve the tension from the park brake cable by pulling down on the park brake cable in front of the equalizer then removing the cable from the equalizer bar.
  2. For the 25/35 series Disable the park brake cable automatic adjuster.
  3. Raise and safely support the vehicle.
  4. Remove the tire and the wheel.
  5. Perform the following procedure to remove the cable (2) from the backing plate (4):
    • Compress the spring (3) by pushing toward the lever (1).
    • Depress the locking tabs.
    • Pull the cable housing out of the backing plate (4).
    • Remove the cable (2) through the slot in the backing plate.
      Lever (1), cable (2), spring (3) and backing plate (4)
  6. Remove the park brake cable (2) from the lever (1).
  7. Remove the rotor.
  8. Remove the rear axle shaft.
  9. Remove the park brake shoe return spring (6).
    Park brake shoe assembly 1500HD, 25 and 35 Series
    Click to Enlarge
  10. Remove the park brake shoe anchor springs and pins.
  11. Separate the tips of the shoes from the park brake actuator and remove the park brake shoes and adjuster assembly from the vehicle.
To install:
  1. Clean the debris and the dust from the park brake components using a clean shop cloth.
  2. Install the adjuster assembly to the park brake shoes.
  3. Separate the tips of the shoes and install the park brake shoes to the park brake actuator.
  4. Install the park brake shoe anchor springs and pins.
  5. Install the park brake shoe return spring (6).
  6. Adjust the park brake shoe.
  7. Install the rear axle shaft.
  8. Install the rotor.
  9. Install the park brake cable (2) to the lever (1).
  10. Perform the following procedure to install the cable (2) to the backing plate (4):
    • Compress the spring (3) by pushing towards the lever (1).
    • Route the cable (2) through the slot in the backing plate.
    • Push the cable housing into the backing plate (4) until the locking tabs snap into place.
  11. Install the tire and wheel.
  12. Remove the safety stands.
  13. Lower the vehicle.
  14. Enable the park brake cable automatic adjuster.
  15. For the 1500HD, install the park brake cable to the equalizer by pulling down on the park brake cable in front of the equalizer then installing the cable to the equalizer bar.
  16. Adjust the park brake cable.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 23; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos'; shinehutt_0.gif
Jan 13, 2011 | 1995 Ford F150 Styleside Regular Cab
How to install usb data cable
A USB cable driver is need to be installed for the USB cable to work and this driver comes with the cable itself. insert the cd, let the wizard open, click on install and follow the steps or after the wizard is open, click on the option for installing driver for USB cable. Enjoy !!! Thanks for using fixya !!!
Nov 11, 2010 | Nokia 7210
How to installing brake shoes on back ?
First you have to compress the parking brake cable spring and attach the parking brake lever.
Clean and lubricate the brake backing plate.
Use silicon Brake Caliper Grease and Dielectric Compound.
Then,
install the rear brake shoes and linings:
1) position the rear brake shoes and linings
2) position the parking brake lever
3) install the brake shoe hold-down spring pins and the brake shoe hold-down springs.
Install the parking brake strut
1. install the parkig brake link spring on the parking brake strut
2. install the parking brake strut
3. Install the brake shoe anchor ping guide plate.
Install the short brake shoe retracting spring
1. Place the brake shoe adjusting lever cable over the anchor pin, with crimped side in
2. Install the short brake shoe retracting spring
Note: Make sure the brake shoe adjusting lever cable is positioned in the cable guide groove
Install the long brake shoe retracting
1. install the cable guide
2. position the brake shoe adjusting lever cable in the cable guide groove
3. install the long brake shoe retracting spring
Note: to prevent incorrect installation, teh socket of each brake adjuster screw is stamped R or L
Assemble the brake adjuster screw assembly.
1. apply silicone brake caliper grease and dielectric compound
2. install the brake adjuster screw into the brake show adjusting screw nut to the end of the threads and then loosen one half turn
3. install the brake shoe adjusting screw socket on the brake shoe adjusting screw nut.
Install the brake adjuster screw assembly
1. Position the brake adjuster screw assembly
2. Install the brake shoe adjusting screw spring
3. Position the brake shoe adjusting lever cable
4. Position the adjusting lever return spring and the brake shoe adjusting lever
5. Hook the brake shoe adjusting lever cable to the brake shoe adjusting lever.
Test the operation of the automatic self-adjuster
1. Pull the brake shoe adjusting lever cable and check that the brake shoe adjusting lever rotates the brake shoe adjuster assembly
2. Release the brake shoe adjusting lever cable and check that the brake shoe adjusting lever advances to the next notch on the brake shoe adjusting screw nut.
Adjust the brakes.
Install the brake drum.
Thats it
Sep 10, 2010 | 1998 Ford Ranger SuperCab
Where is my starter and how do I change my starter?
2000 Hyundai Elantra 2.0L MFI DOHC 4cylRemoval & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Speedometer and shift control cables Starter electrical connectors Starter motor
    Fig. Exploded view of the starter-XG 300 and XG 350
To install:
  1. Install or connect the following:
    Starter motor and torque the bolts to 25 ft. lbs. (34 Nm) Starter electrical connectors Speedometer and shift control cables Negative battery cable
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    Negative battery cable Air intake assembly Speedometer cable Shift cable Starter wiring connectors Starter motor
To install:
    Starter motor and torque the bolts to 20-25 ft. lbs. (26-33 Nm) Starter wiring connectors and torque the battery cable nut to 88-140 inch lbs. (10-16 Nm) Shift cable Speedometer cable Air intake assembly Negative battery cable
To install:
To install:
    Starter motor and torque the bolts to 25 ft. lbs. (34 Nm) Starter electrical connectors Speedometer and shift control cables Negative battery cable.
All Others
    Negative battery cable and wait at least 3 minutes Speedometer cable and shift cable from the transaxle Starter motor wiring Starter motor bolts and the starter
To install:
  1. Installation is the reverse of removal. Tighten motor retainers to 20-25 ft. lbs. (27-34 Nm).
Hope helps (remember rated this).
Jul 14, 2010 | 2000 Hyundai Elantra
Dead battery
Removal Procedure
Disconnect the negative battery cable
Remove the wheelhouse liner.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Install the battery hold down retainer and bolt.
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts.
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Install the positive battery cable (1).
Tighten the positive battery cable bolt.
Close the positive battery cable connection cover.
Install the wheelhouse liner.
Connect the negative battery cable
Oct 15, 2009 | 2006 Pontiac Solstice
My monitor will not work with the originally installed dvi cable but works with svga cable only, The dvi cable was installed when new 2 years ago. I installed new dvi cable ...no luck. I installed a vga...
Try this if you haven't already, UNPLUG THE MONITOR FROM THE WALL.
LEAVE UNPLUGGED FOR 5mins and PLUG IT BACK IN AT THE WALL.
Alternatively try another dvi cable could be a dodgy cable.
Aug 01, 2009 | Gateway Computers & Internet
Free download connectivity adapter cable CA-45
I HAVE BUY USB CABLE TYPE CA - 45 AND THE INSTALLATION CABLE, BUT IT DOES NOT INSTALL IN THE COMPUTER, HOE SHALL I GET THE CORECT SOFTWARE.
May 07, 2009 | Lands Phones
Installing usb cable without cd
you can not install the cable it is the device atteched with the cable that gets installed.to install a usb device with out cd insert cable into device and then the computer.you should see a small window that says :new device found: then installing device then:
installation failed no drivers found etc...now at this point you tell the computer to search online for appropriate drivers. if this doesnt't work write me and tell me what the device is and i'll help you find appropriate drivers
Apr 23, 2009 | Computers & Internet
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
16 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
