Question about Honeywell 3800g Barcode Scanner PN 3800G14SERKIT3E Handheld Barcode Scanner
3800g handheld barcode scnaner not working on windows on windows 7 professional. It used to work and now we are getting a Windows has stopped this device because it has reported problems. (Code 43) any ideas on how to fix this problem
3 Suggested Answers
  • 61 Answers
SOURCE: Keep getting error Cannot execute btcc.exe
If your device is registered at Intermec.com you should be able to dowload a firmware flash for the device. Follow the instructions and reflash the device. If this does not work the bluetooth radio could have malfunctioned.
Posted on Apr 05, 2009
  • 34 Answers
SOURCE: I have a Honeywell 3800g Barcode Scanner with a
Most barcode scanners will not use a standard mini-din to USB adapter. You need to replace the cable with a USB cable designed for that bar scanner. Here is a Google shopping result for the cable you need. Good luck!
http://www.google.com/products/catalog?q=honeywell+3800g+usb+cable&hl=en&safe=off&prmd=ivns&biw=1419&bih=695&bav=on.2,or.&wrapid=tlif129971812876510&um=1&ie=UTF-8&cid=1100600390771774037&sa=X&ei=_B94TdetEI6NrQG6p5nuCQ&ved=0CF0Q8wIwAA#
Posted on Mar 10, 2011
Honeywell Barcode Scanners configure for Excel
Find solutions to your Honeywell Barcode Scanner...ask an expert to help you find the right scanner for your application. Honeywell Barcode Scanners for handheld and handsfree bar code scanning
Jan 22, 2014 | Honeywell 3800g Barcode Scanner PN...
Why my nternet stop working
Samsung Series 7 Slate : 1.6GHz processor Windows 7 Professional 64-
Oct 03, 2012 | Samsung Series 7 Slate : 1.6GHz processor...
I would like to use the honeywell 3800g14-usbkite scanner on widows 7. The user guide says that as soon as the scanner is plugged into the usb, the scanner will beep, despite downloading official drivers...
Go to Control Panel. Open Device and Printers. Do you see a picture of your scanner? If not, run the Windows Troubleshooter and have it detect new devices. Iff you do see a picture, right click on the picture and have it update drivers
Nov 01, 2017 | Honeywell 3800g Barcode Scanner PN...
Need installasion instructions as well as program
Hi
Click hear to find the manual read the manual and install the your HoneyWell 3800G
Jun 08, 2011 | Honeywell (formerly Hand Held ProductsHHP)...
My 3800g barcode scanner puts a prefix of ~% before the UPC number. I'm sure the answer is somewhere in the 156 page manual, but to a non-technical guy like me the manual may as well be written in...
Hi
If you have the user guide then go to the page 48(4.3) there all option available, To clear the perfix and suffix, other wise download the user guide to Click hear
May 26, 2011 | Honeywell 3800g Barcode Scanner PN...
Cab't get computer/application to recognize the scanner
This is an older model handheld that utilizes either and RS-232 cable or Symbol Synapse cable to link to a PC. If the model you are using is cordless, then there should be a dock that is used to connect to your PC.
Most computer peripherals using RS-232 connections require a driver install to the PC in order to recognize the input from the device. Upon successful connection of the handheld or dock to the PC with driver installed, the unit should work as long as there is no physical malfunction to the unit.
The driver utility support the p470 models can be found here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11585&sliceId=&dialogID=227820981&stateId=1%200%20227814895
This unit is only supported by Windows 2000 or Windows XP environments.
Regards,
Dan
IT Professional
May 04, 2011 | Symbol P470-SR1211100FB Handheld
Hi, I am trying to install the drivers for my HandHeld 3800G Linear Imager (barcode scanner), but keep getting the following error: "Cannot Install this Hardware There was a problem installing...
you may have to delete the file or uninstall-then reinstall..if this does not work you may have to go to the honeywell site and reload the drivers again as you may have lost a thread during the initial download ...happens more than you think...good luck
May 19, 2017 | Honeywell (formerly Hand Held ProductsHHP)...
Scanning is extremly slow
What interface? If it is a USB interface the scanner sends the numbers the same as if you had entered them on the keyboard. If you do just enter the barcode (need to know format actually sent to application) numbers does it also respond slow?
Plug the scanner into another PC/laptop, open notepad and scan a barcode, does it scan fast?
The POS application, if it is windows, open notepad and scan the barcode, does it scan faster.
It is likely the POS application that is responding slow.
For the POS applicaton:
- Is scan database local or on the network.
- Have you maintained the scan database? Re-index, compacting, etc
Apr 13, 2010 | HHP 3800g Handheld Barcode Scanner
Honeywell 3800g Barcode Scanner  PN 3800G14SERKIT3E Handheld Barcode Scanner Logo
161 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
