Question about Archos 605 WiFi Digital Media Player
Archos 605 battery replacement
How do I replace the battery on the Archos 605?
  • 3 more comments
  • Anonymous Sep 09, 2008
    same problem as the other person what part dont you understand
  • Anonymous Feb 24, 2009
    Same issue, how do I replace the baattery once I've bougght a new one? no retailers seem interested in letting the secret out.
  • davethepeg Feb 25, 2009
    My archos 650 wifi 160 gb will only hold charge for 45 seconds it is only 1 yr old just out of warranty.........
  • Anonymous Mar 11, 2009
    what about the 40gb model?
  • Anonymous Apr 07, 2009
    Try this guide for the 80GB models:
    http://alilokhandwala.co.cc/node/30
I purchased the battery at the link listed here
http://www.newmp3technology.com/605-30-battery.htm
The replacement is not easy, but I was successful
tools reqd':
a very small phillips head screw driver (for cover)
a very small allen key (for hard drive removal)
side cutters
solder iron (very small tip)
small shrink tube (or black elec. tape)
remove the back cover (4 small screws top and bottom of the gray back and 4 small screws at the silver sides of the unit) also be careful here as the screen is now loose and can fall away if not supported
remove hard drive (4 small allen screws) make sure you GENTLY wiggle the hard drive out of plug
the battery is now exposed
this was the nasty part, the battery can be removed out the back but you have to pry it out, I ended up prying and bending the battery to remove it (it was do or die at this point). once you have it loose snip the black and red wires leaving about 3 inches.
the new battery dropped into place very easily.
Strip about 1/4 inch off the blacks twine them together and carefully solder (if you twine them end to end make sure you slip a 1" piece of shrink tube over one before you solder, I twined them side by side so I could slip on the tube after) if you use elec. tape instead of tubing MAKE SURE you leave no wire exposed or you unit will likely be forfeight. Repeat process for the red wire making sure the battery lead does not contact anything but the other red lead.
I laid the 2 solder connections along the top edge of the unit so as not to interfere with the hard drive laying flat
reverse the order to reassemble and that should be that!
My new battery was flat on delivery but has now charged up fully and seems to hold a good charge.
Posted on Apr 17, 2009
  • SlartiBfast Jul 26, 2009
    I have since found another guide (with photos here
    http://forum.archosfans.com/viewtopic.ph...
    You may have to sign up for a free membership to view this page, but it is a handy page for Archos owners
  • 3 Answers
Hi :
There is a video on youtube about this issue. Required is a smal screwdriver, cutting two wires (one at the time !!), inserting yr new battery, and reconnecting the new wires to the cut-off ones from the unit. You can solder these two wires, but in that case make sure you use thin shrink tubing, so the blank parts from the splice can not touch each other, and certainly not the casing from your archos unit.
Gerard
Posted on Nov 21, 2008
    Problem Solver:
  • 5 Answers
I just found a place to buy a replacement battery (http://www.newmp3technology.com/605-30-battery.htm) and I was wondering if I can change it myself?
Posted on Sep 02, 2008
    New Friend:
I bought a replacement battery for my Archos 605 WiFi 80GB from MegaCapacity.com (the one marked as 2600Mah), and it turned out to be about 1/2 in too long to fit. I only realized this after the whole unit was disassembled and the new battery soldered and ready to be reassembled. Beware!! I fear that this whole effort was a waste of time and money.
Posted on Oct 31, 2009
  • 4 Answers
Basically you don't  for anything other than the 30gb !!  I only found one link anywhere on the net to change the battery on the 160gb (which is what I have), and you have to completely take the unit apart (including the touch screen and the circuit board.
There is a video on youtube on how to change the battery on the 30gb (this might also be valid for the 80gb).
But if you have the 160gb, then you are stuffed !!! or you pay roughly £80-90 to send the unit back to archos to fix, but their customer service is virtually non existent. I wrote to them and was told that as my unit was no longer sold by them and out of warranty I should just look on archosfans.com !!!!
This type of customer focus is obviously aimed at the consumer buying a new unit rather than fixing the one they have....... All I am going to do is go back to using a PSP again and convert the files to mp4, the batteries are replaceable and the memory expandable.
Mitch
Posted on Jan 11, 2009
  • LoungeLizad Apr 21, 2009
    I had the same experience. I did find detailed instructions but unless you are a complete gadget freak, AND really good with little screws and soldering.....then I wouldn't bother........ I'm only 1 of those..... I can't solder !
    I eventually send my unit back to Archos, apart from the customer service being the worst I've ever come accross... They said my PCB (printed circuit board) needed replacing.... and it would cost £102.
    When I got it back, they service docket said they had replaced the PCB & battery (& frame.... wtf !!!!)
    Anyway, long story short, unless you are very capable, I would just bite the bullet and pay your money !!! As I now have a battery that I paid £35 for and can't use it for anything other than a paper weight !!!
  • rovboy 58 Sep 19, 2010
    I've just removed the battery pack from the 160Gb unit mostly as per slartybfast's advice but ALSO removed the 2 side bars. The screen didn't fall out, I just had to use a bit of GENTLE persuasion. £12.99 replacement off e bay with free postage. Anybody who wants to give me a broken archos is welcome, much too good to throw away just because some tech support hike up the repair price.
    Rovboy.
  • 3 Answers
You can get a replacement battery for the 160gb model from here:
http://www.mp3extras.co.uk/archos-battery-20gb-40gb-80gb-160gb-models-p-94.html
Although im not sure how easy it is to install ?
Posted on Aug 10, 2009
    New Friend:
How to replace the old battery for archos 605
Posted on Oct 29, 2009
  • kris ram Oct 29, 2009
    hi,
    thanks
Excellent advice StartBfast! thanks
I found it very easy as I do a little electronics myself.
If anyone wants me to fix theirs just supply the battery (or I could) and ill do the replace job for £20.
I have an eBay shop - kas123456 so you can contact me there.
thanks
Karl
Posted on May 04, 2009
  • Davindra Jan 21, 2011
    Hi - are you still around and how much will it cost now in total. Please send me your details. Cheers Dav
    New Friend:
It would have to do by a technician proffesional beacuse it is not easy to do it by yourself.
I bought a replacment battery in ebay and called to proffesional man (I lived in israel) and for lowest price he perfectaly replace it.
if somone here in ISRAEL want his number: 054-4588367 and his name Yehiel Daniel .
Posted on Feb 01, 2010
3 Suggested Answers
SOURCE:
  • 1894 Answers
SOURCE: Archos 605 battery replacement
replacing the internal battery needs a service manual sir.
and the service manuals can be got from the company or other site for some small amount sir.
Posted on Aug 02, 2008
SOURCE: how to replace battery in archos 605
if azune locked and say contact suport? how can I open it
Posted on Apr 18, 2010
Can I change the battery on my archos 605
You can get a replacement battery here.
http://www.newmp3technology.com/605-battery.htm
By the looks of it, your need to open it up and unsolder the battery contacts and then resolder them.
If you don't feel up to doing it yourself, then try anywhere that repaires PC, laptop and such.
Check if they will do it and buy the battery yourself, might be cheeper that way.
Also check ebay incase it's cheeper there.
Aug 23, 2012 | Archos 605 Wifi Portable Multimedia Player
Aug 02, 2008 | Archos 605 WiFi Digital Media Player
How to replace battery in archos 605
Apr 18, 2010 | Archos 605 WiFi Digital Media Player
I can't find the model number on my Archos 605 wifi 160gb - can anyone tell me where it is?
serial number or model number - isn't archos 605 is the model number? serial numbers are usually written inside battery compartment or battery cover and rarely displayed via settings/information menu
Sep 01, 2009 | Archos 605 Wifi Portable Multimedia Player
Archos 605wifi not switching on
Hi, my Archos 605 160GB is doing the same, Sorry to say the battery has gone.
2 options
1. Back to Archos
2. Replace the battery yourself I ordered mine from HK from the web site BatteryUpgrade. co. uk for about £24 - If you search on Utube there is a video showing you how to change the battery on smaller 605's
Jan 09, 2009 | Archos 605 WiFi Digital Media Player
Archos charging the battery takes too long
I found that I have to leave my archos 605 powered on to get a full charge out of it, blinking light and all
Jul 18, 2008 | Archos 605 WiFi Digital Media Player
My Archos 605 keeps shutting down after about 1min. Can u help?
Hi,when this happens,please plug USB charger and run the Archos..if it runs immediately the HD and system is okay but the battery should be the faulty element.So just replace the battery.That was the case for my Archos 604 and than after battery replacement it was corrected.
Regards
Kazim ERGUNEY
May 01, 2008 | Archos Audio Players & Recorders
Archos 605 return
erm im sorry but i doubt they will accept it if you have had it for a couple of months. for full confirmation check the warranty information.
sorry
Feb 14, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
23,891 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
