Question about Campbell Hausfeld PW2575 Pressure Washer
I have a 2300 psi gas pressure washer, campbell hausfeld, runs fine but water comes out the nozzle like a hose , no high pressure. inlet filter is clean and when you pull the trigger on the nozzle water comes out like a hose but no pressure
If you no longer have High Pressure coming out while machine is running, it's a pump issue.
Posted on Mar 19, 2011
Campbell Hausfeld 2200 psi pressure washer doesn't build up pressure
2 possibilities. It is not getting enough water from the hose or your pressure regulator is bad. Does it sound like the engine is developing full RPM? Could be and engine problem if not coming up to full speed.
May 04, 2015 | Campbell Hausfeld Garden
I have a 3000 psi campbell hausfeld gas pressure washer and it has no pressue how can i fix it
Small stream sounds like your pump is not working at all - you are getting house pressure only. First check the intake fitting where you attach the hose for debris that may be clogging the water flow. Same for the pressure hose and quick connect fittings. Remove the tip from the wand and see how much flow you get. If it's still only a small amount, with the motor running, you probably have a bad pump. This can be caused by bad seals inside the pump, or by running the motor without maintaining water supply to the pump, which can melt the seals or even seize the pump if allowed for too long. Repairing the pump is typically more work and expense than replacing it, assuming you can locate a replacement pump.
Aug 03, 2014 | Garden
I have a campbell hausfeld 2450 pressure washer with water coming out of a brass hose nozzel right next to where you screw the high pressure to the pump as soon as you turn the water on from the house,...
this is called the chemical injector which enables you to insert the hose for you to dispense the soap and or chemical by utilizing a soap nozzle .apparently inside this barb you will find a ball a spring and a o-ring,find the replacement parts or kit from its manufacturer.finding a plug to replace it is not recommended due to the fact that the pitch of thread is hard to find.replace asap this unit relies on trap pressure to unload.
Aug 04, 2013 | Campbell Hausfeld Garden
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Need the connection for the wand hose to the pump for Blue Max Gasoline High Presssure Washer stock No: PW2200/03435
Your pressure washer is sold under various brand names, however I believe that it is made by campbell hausfeld. Parts are here:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/campbell-hausfeld/PW2200
Take a close look at the pump diagram to make sure it looks like yours. Good luck
Nov 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Campbell Hausfeld 2000 Psi Gas Pressure starts and runs for a stort time then dies out and is hard to start with the water pressure still on. Will run for a stort time only after it has sat fo awhile....
Replace or clean with spray carburetor cleaner, the fuel filter which is likely plugged. Make sure the fuel tank vent is open. Sometimes, a fuel system cleaner is helpful like 'Seafoam". Make sure the oil is clean and topped up. A muffler can sometimes plug up and cause a similar problem. Hope this helps!
May 18, 2010 | Campbell Hausfeld 2000 Psi Gas Pressure...
When pressure washer is running no water is
Most of the time the problem is just debris in the spray nozzle. The hole is very small and it doesn't take much to clog it. If you can remove the nozzle, just take a pin or small piece of wire & poke it through the hole from the front of the nozzle and rinse it off with the hose. If the nozzle cannot be removed, just take the lance apart in the middle and do the same.
Feb 05, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
Campbell Hausfeld PW1380 Pump won't run when water hose is connec
http://www.ppe-pressure-washer-parts.com/campbell-hausfeld-pw138000-pressure-washer-parts
Hope this helps. I have the same problem. It's not the switch but the mechanism that slides inside the switch, which activates the switch to go on and off. I fnally found it so hopefully they have the part in stock. It's not a clogged wand trust me I have torn it completley apart and found out it is the mechanism in the switch is plastic and breaks.
May 19, 2009 | Campbell Hausfeld 1,350 Psi Electric...
When trigger is engaged under pressure nothing happens.
Make sure all of the water is bleed out of it buy holding trigger down with motor not running until theres is not more bubbles or air that comes out..Make sure where the inlet for waters screen is not plugged..You may have to back flush washer to clean out or to unstick the pressure valve..Hope this helps you and have a great day
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 06, 2009 | Garden
Campbell Hausfeld PW2575 Pressure Washer Logo
935 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Steve
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
