Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I need to replace the fuel lines and was looking for a diagram on where each hose goes. Un fortunately they were so rotton the broke off before I could sketch their location
  • Poulan Master
  • 2,239 Answers
There should be three hoses, the hose from the tank with the filter on, goes to the fuel inlet on the carb, this is the connection closest to the pump cover held with one screw, the other pipe from the carb closest to the metering side, goes to the short connection on the back of the primer, this is the suction side, the hose from the longest conection on the primer, the pressure side, returns to the tank.
just remember the primer pulls fuel from the carb, and dumps it back into the tank, not the other way round,
Posted on Mar 19, 2011
97 acura cl gas gage not working
looks like your fuel sender and pump are in your tank. run it out of gas or drain it , drop the tank replace fuel pump and filter and sender unit at once. check for rotton hoses, leaks , old gasket should be replaced.
after market parts that meet OEM are ok. don't use rebuilt stuff
Oct 28, 2013 | Sew Eurodrive Motor Drive Unit Drive...
I have a craftsman 358.797931 w/ a walbro carb with primer bulb on top.what line takes the fuel filter and which line goes where on carb. Top and lower tubes
The hose with the fuel filter will go to the bottom of the carb, the top hose off the carb will go to the inlet of the primer and the primer outlet will return to the tank
Feb 04, 2013 | Garden
Need a diagram of fuel line routing
Right you have three hoses, there are two holes in the tank unit, the smaller of the two holes ( too the left hand side as you look down on top) this is the main fuel hose which has the fuel filter on the end in the tank, this then fits to the right hand connection on the carb, there is then a short hose which connects to the carb on the left hand side, and then goes to the shorter of the two connections on the back of the primer ( suction side ) there is then a hose from the longer connection on the primer( pressure side ) back to the hole to the right hand side of the tank , so to recap the primer pulss fuel from the carb, into the primer bulb, and dumps back to the tank.
Sep 09, 2012 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Vacum hoses loose, where do they go? 1990 ford f150 4.9
There was a diagram under the hood from the factory of the hoses. We do not have the diagrams.
Jun 14, 2012 | 1990 Ford F150
Un connected vacum line,apprx.6'' long,cannot find where to connect,looked everywhere within lengt of line.97 sentra vacum skamatic diagram needed.causing chk.eng.lite to come on.p0440.purge...
Hi Michael: here you have two diagrams...
DTC P0440 code indicates that a part of the EVAP control system is no longer fuctioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
A code P0440 could mean one or more of the following has happened:
  • The gas cap is not installed or working properly
  • The purge solenoid has failed
  • The canister is plugged and not working properly
Additional details could find in this links Fault Codes on Cars & Trucks or other diagrams in Cars & Trucks Vacuum Diagram.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 07, 2011 | 1997 Nissan Sentra
My son was changing furl filter on 1998 ford explorer, did not have tool, so he broke braided fuel line in front of fuel filter, can't find diagram to see how to replace it.
If he broke the plastic fuel line connector, you can
get that at the auto parts store
If you talking fuel line or hose damage,just remove it
and get at the dealer
Mar 14, 2011 | Ford Explorer Cars & Trucks
Fuel line in tank broke off need to know if fuel tank can be taken apart to replace hose and if so how
No the fuel tank is part of the case. The fuel line needs to be pushed through the holes. The supply line goes through the big hole on the left. And the return line goes through the small hole on the right hand side.
It is tricky getting the lines through these holes, It helps to use a small pick or punch to push with, then I use a hemostat to reach inside and pull the lines in. Use bulk line and dont cut it until you are happy with the length. The supply line ( the one with the filter) should extend outside the fuel opening. The return line just need to enter the tank about an inch or two.
Hope this helps
Nov 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need a repair diagram for a poulan 2050 that shows just where each gasline goes. Anyone know where to go?
the bottom fuel line that goes to carb lower port also goes to the fuel tank look inside fuel tank threw gas cap hole to find the fuel filter hose is picking up the fuel and bringing the gas to the lower fuel port into carb (the upper from carb goes to prime or return to tank)
May 09, 2009 | Poulan Pro Chain Saw 46cc 20"
Broken line after fuel pump replacement
All the fuel lines in the modern fuel pump in tank vehicles need the 2-3 lines hooked up, so it would be a good idea to do so. Rick
Apr 13, 2009 | 1999 Ford Explorer
How to replace the Husqvarna chainsaw fuel line.
let me knoe the model number and i'll see what i have....
Oct 29, 2008 | Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
856 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
