Question about Microwave Ovens
How do u take the hose of a creda excell 1200 washing machine
    Brigadier General:
  • 8,909 Answers
Which hose?
Posted on Mar 19, 2011
Why wont My Daewoo DWF-750 washing machine not empty water automatically
You've probably got some debris in the pump, or blocking the pump inlet. If you can do this without making a mess (or shocking yourself,) try backflushing the drain hose.
May 06, 2014 | Microwave Ovens
Ignitor keeps clicking on burner
A creda microwave oven doesn't have an ignitor or burner, so I assume you are talking about either a BBQ grill or gas range.
A suggestion: Clean the ignitor tip with a CLEAN and DRY green scouring pad; check that you have gas coming out of the burner.
If you have gas at the burner and the ignitor is clicking (sparking) then it is usually an ignitor alignment problem where the ignitor got bumped out of position.
Jun 06, 2011 | Creda Microwave Ovens
Creda excell washing machine wont drain water how can i check the hose for blockage
Get a basin and drop te hose down to floor level if it flows easy then its free of blockage...
Mar 19, 2011 | Microwave Ovens
Machine goes thru all the wash cycle but gets to last min and keeps spinning then comes up with f11
Not knowing what sort of machine you have, one of these should help.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
F11 - Pump cannot be activated - Book a washing machine repair.
F11 - Heater timed out. The heater has not reached the required level. Book a dishwasher repair.
F11 - No pump connection - Book a tumble dryer repair.
Mar 17, 2011 | Microwave Ovens
Creda topline duble oven. The single element of the upper oven is broken and its support from the roof is corroded. Can this be repaired?
The upper heating element can be replaced -- easy enough -- element costs $30 - $70.
Sheet metal can be installed over hole(s) in top and re-drilled for the element supports.
Typically, however, an oven which has holes in the liner is very old and will have other pending problems and should probably be replaced.
Charlie
Jan 05, 2011 | Creda Microwave Ovens
User manual for creda contour 48435
If you Google Creda's web site with your model number, you should find that all the information you require is there and probably free of charge!
Hope this helps.
Oct 20, 2010 | Microwave Ovens
I have a whirlpool magic 1200 and it doesn't drain. Can someone help please
First, check the lid switch, the lid was probably dropped and it broke the switch. Next, disconnect the drain hose and make sure it is not plugged up. You could have a sock or something stuck in the hose that would stop the water from draining. After you do that, check the belt on the pump and then the pump to see if it is working correctly
Feb 08, 2010 | Whirlpool GH7208XR Convection / Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
