Question about Toshiba Televison & Video
I have a Toshiba 34HF85, watching it this morning there was a electric buzzing sound and it went off. There is no LED lite in the front, and I can not turn it on. I unplugged it and waited 1 minute re-plugged it back in, and there was that buzzing sound coming from the back of the set where all the cables plug into it. What can it be?
    Top Expert:
  • Toshiba Master
  • 75,571 Answers
Hello
from your description is about the shorted LOT. LOT or Line Output Transformer, is a stepup transformer, looks like a black cylindrical mass from which normally three wires comes out and one amoung them will be fitted to the top of the picture tube, and the other two's will be connected to it base card. if this transofrmer shorts, there will be no power light and no picture or sound. It is a main and crictcial component in your TV. It can be replaced. But should be replaced with same type and number. you must open your Tv to resolder it out from the circuit board and to solder a new one in place. You must have a concept of soldering and some knowledge in electronics. along with LOY the horizontal output transistor also must be replaced. it is small component with three terminals, can be lcoated very near to the above said LOT, screwed on to a metal heatsink. Jusr replace this transistor first before replacing the LOT. In rare cases, if this transistor gets a leak , the problem you described here will arise. So first buy and replace the transistor. After replacing it, just switch on your TV for a short time, say 10 seconds or so, switch it off and feel if the replaced transistor overheats or not. it may get slight warm, but should not overheat. if overheats, it is clear that LOT has got damaged, and should be replaced. OK.
Posted on Mar 19, 2011
Testimonial: "THANK YOU FOR YOUR IMMEDIATE RESPONSE. My son will come over and see what he can do."
Toshiba 34HF85 code for ONN ONB13AV004 remote
Your universal remote probably has a "code search" feature that allows you to search its entire code libary to find something that will control some or maybe all functions of your Toshiba TV. If a thorough search does not produce a result, you may have to try another remote.
Aug 19, 2014 | Toshiba 34HF85 34" TV
My toshiba led tv will not turn on, does not seem to have any power when plugged in...model# 32SL41OU
I would suspect a faulty power supply board, but could also be an issue with the main board.
Dec 21, 2012 | Toshiba Televison & Video
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and...
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
Oct 14, 2011 | Samsung DLP HL-P5663W 56" TV
Dryer making a buzzing noise
It sounds like your motor has gone bad....it will buzz or hum when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 13, 2010 | Frigidaire Electric Dryer
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
No Visual; Only Audio
No real specific suggestion but it's likely serious. Very likely in the hi-voltage section and quite possibly the flyback transformer; too expensive to bother with if so.
May 13, 2009 | Toshiba 34HF85 34" TV
No picture, buzzing sound
It sounds like the horizontal output transistor may be shorted....Can you feel any static charge on the face of the pix tube?
Nov 15, 2007 | Toshiba 36A43 36" TV
1997 Toshiba TP48G10
not sound, not imagen, with you conect to power the relay is down
Sep 30, 2007 | Toshiba TP50G60 50" Rear Projection...
Televison & Video Logo
151 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
